Has anyone who has done this written up a tutorial on it that they'd share with me. The service manual seems to be a little thin on the subject. to wit: "Wait until the coolant cools down, and then drain the coolant." - & that's it!
Is there a sequence in disassembling? I've got the radiator & battery box off. It looks intimidating beneath & forward of the battery box area. Does the inner fairing have to come off? What about the air box? BTW, I did the coolant manifold O-rings 40k ago.
coolant hoses replacement help needed
- richardb, austin
richardb, austin
__________________
__________________
