Front axle torque
- Current bike(s): 1986 Voyager xii 1200
Front axle torque
I just finished replacing the tires and bearings on my bike. Anyone know what the torque on the front fork pinch bolt is supposed to be?
- grumpin
Re: Front axle torque
The axle nut is 65 ftlbs., according to the FSM. If that's' what you mean by pinch bolt.
Dane
2000 Voyager
2000 Voyager
Thanks!!!! What would happen if i did 80? I read somewhere it was 80 so i did that today...
- richardb, austin
What I would think of as a pinchbolt is what keeps the RH end of the axle from spinning as you tighten (or loosen) the axle bolt. It's officially called "the axle clamp bolt" & requires only 10 ft# of torque. It is pictured on page 9-4 & in the suspension chapter - page 12-2 of the Svc Manual.
richardb, austin
__________________
__________________
