CB not Working
- rustynut51
CB not Working
cb blew the fuse . replaced the fuse . everything works ok
but the display is blank . the backlight works for the screen
all the controls work . why it blank
- Bill O
2003 1200 Voyager
- Been liked: 6 times
Re: CB not Working
The CB Control head tends to do this at times. I found that if you remove the positive lead from the battery, wait a couple seconds, then reattach, the numeric display will miraculously reappear.
Bill O
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
1994 Voyager
2003 Voyager
- rustynut51
- rustynut51
- suzib6sw
- Tourer
Re: CB not Working
The main thing that will cause this is water has gotten onto the chip inside the controller.. OR the data line from the CB main silver box to the controller is broken..
If its the latter, that can be fixed..
If its the former, then you need to look for a new controller or send it to me.. I have some innards and can repair it..
Pete
Pete
Pete
1986 Voyager XII
1986 Voyager XII
- rustynut51
Re: CB not Working
no water. fuse blew when i tried to use first time with head set
have tried to use without it hooked up still blank. but works great .
- suzib6sw
- Tourer
Re: CB not Working
rustynut51 wrote:no water. fuse blew when i tried to use first time with head set
Hmm.. then it may have caused damaged to the actual CB unit.. I would need you to send me both items for me to check it out..
Phone number and site in the SIG below..
Cheers..
Pete
Pete
1986 Voyager XII
1986 Voyager XII
- rustynut51
Re: CB not Working
guess i forgot . after replaced all was well worked for awhile
then the face went blank.
- chevyman1
- Board Member
- Been liked: 16 times
Re: CB not Working
Try pulling the plugs apart that go to the display unit sometimes they loose contact.
- rustynut51
Re: CB not Working
did that didnt help . about time to put it away here might wait till spring to fix it
- suzib6sw
- Tourer
Re: CB not Working
If you are going to put it up for the Winter, then why not send the box and/or controller down to me .. Let me take a look at it get it ready for you for springrustynut51 wrote:did that didnt help . about time to put it away here might wait till spring to fix it
Pete
1986 Voyager XII
1986 Voyager XII
- rustynut51
