Radio not working on fm
- Current bike(s): 1987 voyageur
Radio doesn't want to switch to fm when I hit the fm button. Problem or am I missing something.
- gan
- Current bike(s): 2000 XII
1996 XII - Location: Binghamton,NY (upstate, not city)
Re: Radio not working on fm
Sorry, probably broken "bubble switch," not an easy fix once water got in there. Look elsewhere for XII radio repair.bob1665 wrote:Radio doesn't want to switch to fm when I hit the fm button. Problem or am I missing something.
2000 (Blue/Silver) Voy 12 RATT 100K
1996 (Blue/Silver) Voy 12 53K
- Bill O
2003 1200 Voyager
- Been liked: 6 times
?Question..... Will it switch to HS and back off? If not, the problem could very well be a loose or missing circuit board screw behind the right row of buttons. When the screw(s) come loose or fall out, the narrow circuit board will then flex when you try to switch between functions so that it appears that the switches are not working.bob1665 wrote:Radio doesn't want to switch to fm when I hit the fm button. Problem or am I missing something.
I can't count how many of these I've had to repair. Pete knows, too!
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
1994 Voyager
2003 Voyager
it does switch but I am going to go without sound this summer it works very intermittently at best and I will pull it and have it redone this winter.
- suzib6sw
- Tourer
Bob.. and others..
This could be a broken switch as has been stated, but the end screw by the HS button is not the only one to come loose..
I often find many of the other screws loose as well as then end one..
Be aware that if it is just a loose/missing screw, it , unlike the HS screw is free to float around in the actual electronics of the radio instead of getting (typically) wedged in the cassette mechanism..
Anyway, when you are ready, give me a call..
Cheers..
Pete
Cheers..
Pete
Pete
1986 Voyager XII
1986 Voyager XII
