hole in the airbox
- Current bike(s): Kawasaki 1991 Voyager XII
Honda 2016 Africa Twin
Honda 2003 SuperHawk 996
Yamaha 2015 FZ-07
Honda 2009 XRL650
Honda 1982 NightHawk 450
Honda 1971 CB350
Honda 2014 Grom 125
Honda 1971 CT90 - Location: Austin, TX
- Has liked: 2 times
hole in the airbox
I'm going to go for broke here,
I see a hole in the airbox with a grommet in, I see nothing to plug into that hole.
What is supposed to b there?
- Has liked: 107 times
- Been liked: 278 times
Re: hole in the airbox
the "Clean Air System" starts there with a rubber pipe which comes from inside the airbox, through the rubber grommet and leads to a cylindrical "muffler", then another rubber pipe which goes to the vacuum valve. From the vacuum valve 2 rubber pipes go to the 2 reed valve covers, 1 on each side of the top of the cylinder head cover.
If you do not have the system, plug this hole as it is downstream from the air filter element and may allow dirt and/or contaminants to enter the cylinders.
- Chris near Kansas City
The hole should be on the RH side. But if you have a California emissions bike, I believe there is another hole on the LH side. If that setup has been removed, someone may have forgot to plug that hole.
Yamaha 2015 FZ-07
Honda 2009 XRL650
Honda 1971 CB350
Honda 2014 Grom 125
FYI, an auto parts store should have rubber grommets of a size that will fit that hole.
- Current bike(s): 2003 1500 Vulcan Classic
1991 ZG1200 Voyager XII
1982 450 Honda Night Hawk
1993 ZG1200 Voyager XII - Has liked: 0
Talking about the air box is there any aftermarket air filters to do away with stock air filter box sort of like used to be used on the old Honda 750 - 4cyl. The rubber on mine doesn't want to cooperate any more.
Very few have tried 4 small cone filters. Most find that the OEM intake setup works the best.
- Been liked: 238 times
The Honda DOHC 750's used Constant Velocity carb's... It is pretty much impossible to make pod filters work on CV carb's. If the Voyager has CV carb's, don't waste your time, or money (copious amounts of both!). The OEM air box, on the DOHC 750's, were built to supply the correct pressure/vacuum required by the CV carb's, to work properly. On the earlier 750's, with non-CV carb's, pod filters would work just fine.
Ask Carl Leo about whether pod filters would work, or not, on the Voyager XII. He would know for certain. Cheers!
The Voyager XII has CV carbs on her. VM carbs were used on older kawasaki and Suzuki bikes of the 70's.
Yamaha 2015 FZ-07
Honda 2009 XRL650
Honda 1971 CB350
Honda 2014 Grom 125
The grommet is there, just need a plug. Or duct-tape.Mr Jensee wrote:FYI, an auto parts store should have rubber grommets of a size that will fit that hole.
- Current bike(s): 1989 Voyager, 2004 Honda Interceptor
I tried experimenting with cone filters on the carbs, don't even try it.
The only thing I may try is to 3d print a custom intake manifold that is roughly the same shape and leads to a CAI style filter that fits in the same place under the faux tank.
