audio system fuse location
- Current bike(s): 1991 Voyager 12
2007 Harley RoadKing
1981 Honda GL500 Interstate
1996 BMW R1100RT
1971 Yamaha RT1 360
1962 Honda Benley CA95 Touring Model - Has liked: 0
While messing around with my sparkplugs I somehow killed my radio/tape player.I have power to the unit but only a whisper out of the speakers.The mute button isnt pressed.It looks like i have no power to the amp.The manual shows a couple of inline glass fuses but I cant figure out where they are located.Its not the three amp plastic fuse in the fuse box,it must be one of the two inline fuses.Maybe if I knew where the amp was mounted I could trace it back?I have had enough dissapointments for one day.Any help would be most appreciated
- Has liked: 106 times
- Been liked: 275 times
Re: audio system fuse location
http://www.zg1200.com" onclick="window.open(this.href);return false; in case you don't have any of the literature needed.
The amp, and it's 7.5A fuse, is attached to the underneath of the RH inner fairing.
Search youtube.com for videos by Igozum, such as removal of voyager XII fairing etc etc.
You may have the HS button pressed on the radio. HS stands for head set so this almost cancels the speakers. Sometimes a screw inside the radio faceplate backs out and this button becomes locked on.
The glass fuses for the radio are accessible when the headlight bezel and light unit are removed. They are at the rear of the radio.
1996 BMW R1100RT
1971 Yamaha RT1 360
Thank you.I have the service manual,supplement and the radio booklet.The one picture i found showing the location wasnt enough for me to identify the location.Thank you for your reply.
