speed o meter cable
Jimvoyager01
Current bike(s): 2001 voyager
speed o meter cable
Post by Jimvoyager01 »
Question,,,is the speedometer cable supposed to run between the front forks or outside the left front fork?? :thanks: :thanks:
Neal
Tourer
Tourer
Re: speed o meter cable
Post by Neal »
It'll work OK either way, but by going to the outside it'll last WAY longer
doug of so fla
Current bike(s): 07 gold wing
Post by doug of so fla »
Neal wrote:It'll work OK either way, but by going to the outside it'll last WAY longer
+1 Routing on the outside is a straighter run for the cable, less bends less friction. Clean & Lubed with Marine white lithium grease every time front wheel comes off and put a little o-ring at bottom of cable to keep moisture out & should last well over 100,000 mi..
