where is the radio fuse located
Rodney
Current bike(s): Kawasaki Voyager XII 2001
Post by Rodney »
Where is the radio fuse? The manual says to remove it before disconnecting the battery. I can't find it. :hmm:
ghostler
Has liked: 2 times
Been liked: 10 times
Re: where is the radio fuse located
Post by ghostler »
Rodney wrote:Where is the radio fuse? The manual says to remove it before disconnecting the battery. I can't find it. :hmm:
Rodney, you must be referring to Page 15-2 Electrical System in the Service Manual. That 3 Amp fuse is located in the Main Fuse Block toward the front right under the false fuel tank cover. It is the first and only 3 Amp fuse on the left, for audio memory power (CB and main) and the trunk light.
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
voyager55
Current bike(s): 2003 1200
Post by voyager55 »
I've never touched that fuse when removing the battery. No problems
ghostler
Has liked: 2 times
Post by ghostler »
(Duplicate deleted)
ghostler
Has liked: 2 times
Post by ghostler »
voyager55 wrote:I've never touched that fuse when removing the battery. No problems
I never did either and haven't had any problems thus far, but there is a reason why Kawasaki put that Precaution there.
Kawasaki Voyager XII Service Manual wrote:15-2 Electrical System, Precautions
  • To prevent damage to the audio system, do not connect or disconnect the battery leads without removing the 3-amp audio fuse in the fuse case.
My guess is that any spark that may be generated when a battery cable is removed can induce a voltage spike high enough to possibly destroy sensitive electronic circuits.
Perhaps that neither your or I had problems could be pure luck more than anything else? :oh:
Next time I disconnect the battery I will unplug that 3 Amp Audio fuse first, Can't go wrong. :hmm:
George Hostler
Clovis, NM, US
1971 Honda CB100
Has liked: 852 times
I never removed the fuse either,and have not had a problem :hmm: I might want to pay attention next time I disconnect the battery :bat:
To me that makes on sense if you get a spark and cause a surge by unhooking the battery whats to say you won't get a spark and cause a surge when pulling the fuse. :hmm:
I unhooked a battery many of times and never had a problem.
But now we all know that the next time I hook the battery up the radio won't work :oh:
Has liked: 106 times
Been liked: 275 times
Just a guess but I think pulling the fuse or disconnecting the battery, or conversely, installing the aforementioned, WHILE the radio is turned on could lead to problems. For myself, I always turn the radios off before disconnecting and then reinstalling any power leads. YMMV
ghostler
Has liked: 2 times
Post by ghostler »
CMOS (complementary metal-oxide semiconductor) semiconductors and microprocessors can easily be damaged by voltage spikes, including static electricity. http://www.electroschematics.com/4313/s ... ecautions/has an explanation.
The pulling of the 3-Amp Audio fuse is rather benign. With trunk lid closed and radio off, the current to keep radio settings stored is very low.
George Hostler
Clovis, NM, US
1971 Honda CB100
Rodney
Post by Rodney »
Ok thank you guys I found it. I pulled it to save having the clock drain the battery during the winter storage months. I do put a conditioner on the battery but want to minimize any load.
fmjnathan
Current bike(s): 1987 Voyager
Post by fmjnathan »
Ha, I did not know about pulling the 3 amp fuse. I pulled the battery for winter, and this spring my radio doesn't work.
Been liked: 134 times
fmjnathan wrote:Ha, I did not know about pulling the 3 amp fuse. I pulled the battery for winter, and this spring my radio doesn't work.
Oh it may still work, but will default to AM and all stored memory stations are lost. Try it again , press FM and scroll some stations.
