Trailer too heavy?
- richardb, austin
Trailer too heavy?
I loaded up the Coleman Caboose to test for an upcoming 65 mile ride & weighed it. 275# gross including 50# on the tongue. Is that too much for a short trip on my skinny little 8" tires? I'm gonna do a test run tomorrow with this load unless you guys are too discouraging.
richardb, austin
__________________
__________________
- Chris near Kansas City
50lb on the tongue sounds like a lot, but that just might be me. I don't know what my HF/Sears trailer weighs in at, but I try to keep the tongue weight around 20 or 25 max.
- Torch
Everything that I have read on tongue weight says it should be in the 20-30 lb range so that the trailer pulls correctly.
If the T/W is too much then you "feel" the trailer more, especially at slower speeds. If you have a passenger on and add 50 lbs more on the back of the bike, it tends to lighten the front wheel, then you can REALLY feel it! Not one that you want to feel going around corners.
BTW, you probably only need about 20-25 lbs air in the tires as you are only carrying about 25% of the max load on them.
The wind in your hair, the smile on your face,...............................obviously your not at work!
Torch and Brat
(aka: Bruce & MargieB
88 Voyager XII
AVA #5494
Torch and Brat
88 Voyager XII
AVA #5494
With that much weight, 25lb seems low. For what it's worth, the guys on the trailer towing forum said one way to check your tire pressure if you aren't sure, is to load the trailer up to pulling weight, and roll it through a puddle and watch the tread mark of the tire on the dry pavement. You should have an even footprint across the width of the tire mark. If it's thin in the middle, then you need more pressure, if it's thin on the outside, then you need less. I haven't tried it, since I'm basically running the same trailer setup as half the guys over there and all I did was copy what worked for them.Torch wrote:BTW, you probably only need about 20-25 lbs air in the tires as you are only carrying about 25% of the max load on them.
- richardb, austin
Well, I've got 70# of Sears MC jack in the front end of the trailer, so I can easily reduce the tongue weight some- maybe not down to 25ish #. I'll report back after my test ride tomorrow. I'll check the mud print also - or are you just trying to get me to get the bike dirty? ![Laughing :lol:](./images/smilies/icon_lol.gif)
richardb, austin
__________________
__________________
- voyagerjohn
Tongue weight?
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
John
- MTN99
Richardb,
Another thing to keep in mind when loading is to load so things don't shift/move when underway...
.. I try and pack things in a fashon that the heaver items (camp stove, lanterns, ect )are above the axle and other bulky things (sleeping bags, clothes ect) are used to take up the space... (but you probably allready know this)
Also for added ballast we have the Ice chest on the toung.
On our Piggy I try to keep the hitch weight 'between 20-25 +/- lbs and keep the tires at 25psi (cold)
Pack the bearings on the 8"rims/ tires beginning of season and we're good to go..... 8)
Ride safe
![Shocked :shock:](./images/smilies/icon_eek.gif)
Ride safe
Now Retired
Tony & Gail
Grass Valley Ca.
Tony & Gail
Grass Valley Ca.
- WingNutLori
- Current bike(s): 1990 Honda Goldwing GL 1500
Trailer Horror Story
I'm reading this conversation and having flashbacks to July 4th, 2007. We had just started our journey to the AVA Rally in Rapid City. (BTW... that was my first big trip on a bike & first time traveling the Interstates & my first time pulling a loaded trailer!)
As we slowed down on the exit ramp in London, Ohio (for gas), I could hear a terrible noise. I turned off the radio and the noise got LOUDER. What the....? My riding partner let me pass then told me that I was dragging the tongue of the trailer on the ground!
Apparently, the bolt part of the hitch ball came out of the ball, 'cause it (the ball) was still locked into the tongue! Don't know how far I drove like that but there was a good 3/4-1 inch of ball ground off.
I don't know how one prevents such a thing from happening...but color me LUCKY! Everyone that had ever pulled a trailer told me to secure those safety chains "just in case". I didn't lose the trailer thanks to those chains. But I shiver to think what could have happened if the trailer tongue had hooked on a pothole!
So load 'em right and good luck!![:wink:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1f609.svg)
I want to live my life in such a way
that when my feet hit the floor in the morning,
Satan shudders and says...
"Oh crap... she's awake!"
1990 Honda GL1500 - Burgundy/Gray
http://www.keystonewings.org" onclick="window.open(this.href);return false;
....which is one reason I welded a horseshoe upside down near the front of the trailer. The round portion of the horseshoe will keep the lip of the tongue from catching a crack or whatever in the pavement, or, that's the thinking. Plus, it gives me a place to chain the trailer tongue to a lamp post or something. Got one on the back also.
- flip18436572
I'll draw something up. I don't have any pictures of that, or, if I do, I don't know where they are and my trailer is at my brother's house.
edit: I guess one of these days, I need to get the bike and trailer out and spend a half hour taking pictures. It appears, that I don't have any decent pictures of my bike (in one piece) or a complete set of pix of the trailer and bike combo.
[img]http://i27.tinypic.com/jl0w3m.jpg[/img]
- flip18436572
- Mike in Pekin , Il
I have heard the max tongue weight should be 35lbs. also the guys tell me the tongue should be 2x as long as the axle. weight distribution important and you may need to adjust you suspension in back for hauling trailer. If this is your first ride you should take a ride partner.
Ride Safe and Ride Long,
Mike in Pekin, IL
Mike in Pekin, IL
- Barry
- Has liked: 100 times
- Been liked: 69 times
I've tried running my cyclemate trailer with 25 lbs tongue weight and was happy with it in stock form. I lengthened the tongue to where it was twice the width of the axle. This really jacked up the tongue weight and I ended up putting balast behind the rear bumper. It might be 60 pounds heavier, but it sure does track sweet. The rule of thumb I try to live by is 10% of the trailer weight should be the tongue weight. Just my 2c.
- MTN99
Hey Barry
Barry,
Good 2c... We WILL be headed up your way probably in late July early Aug... :D
We'll finaly get to go up the Oregon Coastline to Washington to Victoria Island... Two weeks, (hope it'll be enough time)
Looked for the CVV site ????
BTW somehow your e-addy got placed in our blocked sender list, so if you have E-mailed us since last summer / fall thats the reason for no replys...
Have you got the 57chev on the road yet?
Wishing Good health to You, Vivian & Family
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Now Retired
Tony & Gail
Grass Valley Ca.
Tony & Gail
Grass Valley Ca.
- David (N. Alabama)
I am not sure if motorcycle trailers would differ, but the rule of thumb for trailers is 10 to 12% of the loaded weight should be on the tongue. Less and you risk a swaying trailer. More and you can start to lift the front of the vehicle due to the lever action.
So, 275 lb trailer should have 27.5 to 33 lbs of tongue weight. Make sure your trailer axles and tires can also handle the load.
