Grumpy wrote:Some questions - for TaiwanJohn - I guess if I had the 'scratch' to buy a lift table, I'd do it... but that's making look even closer at just making a piece of my utility trailer removable... However - on the motorcycle lift that just goes under the engine - once the rear tired is removed - would the COG/weight balance change?? that it - would the bike rock forward?
The lift is an investment. Every so often I put a few bucks into tools and gadgets, and now I have everything I need. Just so happens I have wrenched professionally off and on since I was 16. It's not a lucrative career here in small town MN.
As for space, the lift does take some room, but I generally park one of my bikes on it, so it's not a big deal.
I have the saddlebag rails also, so I really don't like unbolting everything. On my lift, I used to use a bunch of wood blocks to hold the bike straight and sturdy while changing tires. This year I invested in one of those screw type jacks for on the lift.
http://www.discountramps.com/zinc-motorcycle-jack.htm It works great. To clear the saddlebag rails you have to lift the rear tire quite a ways up. On a lift, always use straps, and secure the loose ends behind the buckle. Don't trust the buckle alone. One time a buckle let loose, and I almost wore a Gold Wing for a hat.
The bike jack can become off balanced when you pull a wheel, you just have to do trial and error for the best compromise before and after wheel removal. It's probably not for you if your only bike is the VXII. That's why I bought the lift. Lucked out and found it for $250, barely used. Harley guy didn't think it was sturdy enough. He's wrong.
If you don't mind hacking up your trailer, do that. It actually sounds like a very clever plan.
Just make the door wide enough so you can drop the tire straight through the bed as you hang on to it. The HF lift door is kinda small.
