1700 Engine Heat
Wallace18
1700 Engine Heat
Post by Wallace18 »
I just got my Voyager back from its 3750 Service. I had them flush out the original factory coolant and install Engine Ice as per Duane Ash's suggestion. It runs much cooler and a definite differance in heat on the right side. :thmup:
05nomad1600
Re: 1700 Engine Heat
Post by 05nomad1600 »
Wallace18 wrote:I just got my Voyager back from its 3750 Service. I had them flush out the original factory coolant and install Engine Ice as per Duane Ash's suggestion. It runs much cooler and a definite differance in heat on the right side. :thmup:
I'm glad it worked for you, but I heard that you really need to stay on top of it..
I heard that you have to check the fluid level regularly w/ Engine Ice...
Please let me know if that's true...
:thmup:
Wallace18
Post by Wallace18 »
Well I have about 700 miles on the bike since the change to engine ice and I have not noticed any problems at all. In traffic in high ambient temperature the gauge still goes up till the fan kicks on. But once underway the bike runs much cooler. My wife even noticed the differance from the back seat. So far so Good! :pray:
RCK
Post by RCK »
Does anyone know where you can get this engine ice? :hmm:
RCK
dapasda
Current bike(s): 2006 Harley Electra Glide Classic
Post by dapasda »
Here is the Engine Ice website, showing their distributors.
http://www.engineice.com/distribution.html
Screws fall out all the time, the world is an imperfect place. (John Bender)
You see, we're not "The Wonders" right now. We're "Cap'n Geech and the Shrimp Shack Shooters". (Lenny)
Rhinestone Kawboy
1970 Honda CL350 Scrambler
1977 Carabela Marquesa 125 MX
Post by Rhinestone Kawboy »
I believe I have seen engine ice at some of the local auto stores here as well.
Iron Butt Member #47339
RCK
Post by RCK »
Thanks for the replys I have not heard of this before. :thmup:
RCK
Top K
Current bike(s): '09 Kawasaki Voyager ABS
'06 Suzuki C50T
Post by Top K »
The best solution I found to get the bike cooler is a little more pricey than replacing the coolant, but the benefits justify the added expense. I installed an Air Kit from Thunder Mfg along with a Fuel Processor by Cobra (as well as a set of Cobra Tri-Oval Slip-Ons). A Fuel Processor alone will make your engine run cooler - couple that with more air (Air Kit) and you will be amazed how much cooler the bike runs! Not to mention the increased performance - it's just a win-win situation. :wnk2:
'09 Kawaski Voyager ABS
'06 Suzuki C50T
USMC '77-'99
Been liked: 82 times
Cycle Gear has Engine Ice on sale until the end of May here in CA. Which means that Cycle Gear carries Engine Ice.
