Wanna choke it!
berryspatch1
Wanna choke it!
Post by berryspatch1 »
Does anyone have any problem with the choke not really working? On my '89 the choke will work when set at about 1/2, but only for one try. If I don't keep the throttle up, it dies and then it can take several, many, hundreds of attempts to get it started. It wasn't a problem during the warmer months of summer and fall. Lately it has been in the twenties overnight and, although it is a garage queen, it can be difficult to say the least.
Can the choke be adjusted for varying temperatures?or is there something else I am missing? I appreciate any info.
:cold:
2000 1500 Vulcan Classsic
1989 Voyager XII
1986 Intruder 700
2006 Trailblazer SS
38 special
Re: Wanna choke it!
Post by 38 special »
I have an 86 ZN 1300 with nearly the same situation. The choke on or off it makes no difference. I still manually keep the throttle open. I now think it's (after talking with some of theguys here) the valves need adjusting cause she also backfires at low speeds. That'll be an early spring job, as well as a new rear tire.
onegunguitar
Re: Wanna choke it!
Post by onegunguitar »
The "choke" on the 1300 is actually a high idle,it does not serve as a choke.Tight valves will definitely make it hard to start,especially when it has sat for awhile and cooled down.
1999 Voyager XII
David (N. Alabama)
2014 Triumph Trophy SE
Re: Wanna choke it!
Post by David (N. Alabama) »
My '01 Voyager on full choke will bring the RPMs up past 3000. I usually start the bike on full choke and then as fast as I can I move the choke lever to get the RPMs around 2000. As it warms the RPMs creep up so I have to continually adjust the choke while I am donning my gear.
Maybe your cable is stretched or loose. With the choke off, check for play in the cable down by the carburators.
Rhinestone Kawboy
1970 Honda CL350 Scrambler
1977 Carabela Marquesa 125 MX
Re: Wanna choke it!
Post by Rhinestone Kawboy »
Have you checked the condition of your spark plugs lately? Half fouled or worn plugs could cause this assuming your choke and all else is ok. I also highly recommend the iridium plugs also.
Iron Butt Member #47339
