The opener is placed behind that space and held in place with tie wraps for now.
The switch is the flat silver piece closest to you. I soldered on the other side of this but I also removed this switch since some solder went through and was making the opener run all of the time.
This is the backside of the switch, the three solder points.
I had to cut a little notch for the wire to go through. On the inside I had to trim another piece since I did not plan ahead and the cover would not go on straight with the new wire in the way.
I placed the first switch/button in the top right quadrant to allow placement of at least three more switches if needed.
Keithdan
