No Lights
- Nathan (South Carolina)
No Lights
I have a friend with a 2003 VXII who says that when he started his bike a couple of days ago, he had no lights. Has anyone ever experienced this problem? He also said that this has also happened while riding the bike. I suspect that a wire may be loose on the ignition switch. Any suggestions?
Lone Eagle
2001 Kawasaki Voyager XII
- Chris near Kansas City
Re: No Lights
Which lights? Dash illumination? Dash indicators? Running lights? Brake lights? Headlight?
Or all of them?
Or all of them?
- Has liked: 88 times
- Been liked: 153 times
Re: No Lights
Might be (may not be also) the famous "tie wrap" along the left frame under the faux tank. Mine broke an ignition wire and it was less than two inches from the ignition, so the repair was fun. Cut the tie wrap closest to the triple-tree and slowly wiggle the wires to determine if/which wire has internal damage.
Re: No Lights
I had a chance to look at his bike today and all lights are working. We could not duplicate the problem. We wiggled all of the wires to the ignition and found them all to be good. Not sure what caused the original problem.
Lone Eagle
- dapasda
- Current bike(s): 2006 Harley Electra Glide Classic
Re: No Lights
When I first got my bike (8 years ago) I had lots of problems with the lights. It was the main wiring harness past the fuse block, out to the rest of the bike. The connector works lose, the wires arc and burn.
This drove me crazy for a while, as the lights would be working one time and not another. Sometimes I would start a ride with lights working, and someone would tell me later I had no lights.
Screws fall out all the time, the world is an imperfect place. (John Bender)
You see, we're not "The Wonders" right now. We're "Cap'n Geech and the Shrimp Shack Shooters". (Lenny)
Re: No Lights
I just had this happen on sunday thought the fuse blew but after a stop for about a half hour the lights came back in went over all the connectors today and cleaned them wiggled all kind of wires and took the headlight out and cleaned back there as well but havent found anything ..is there a breaker in the system somewhere or a relay for the lights ..relay by battery had some green on it cleaned it all up..am i missing something?
Paul
Paul
