Does someone have a quickly accessible diagram for how to hook up the wires when removing the fader? I find lots of other interesting stuff when searching, but nothing quick and easy...
TIA
Removing Fader
Re: Removing Faader
I pulled up my pdf copy of the audio manual but it has no schematic reference. If I remember fader controls, you have an input and two outputs. the control just shunts resistance to either side. find out which side shunts to the front speakers and splice those together to the input. There should only be + wires going to it. No grounds.
I found an image off the internet that might help. It is for a home stereo surround sound but the wiring of the fader control is esentially the same as you'd find on the Voyager. see the section under "fader"
http://www.termpro.com/articles/faders.html
- Been liked: 134 times
Re: Removing Faader
check out page three of tech tips. its been done before and there are pics of the repair.
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
Re: Removing Faader
Here is that post on page 3, that may be on a later page as more posts accumulate:ekap1200 wrote:check out page three of tech tips. its been done before and there are pics of the repair.
viewtopic.php?f=3&t=3192
Iron Butt Member #47339
- richardb, austin
Re: Removing Faader
I just keep my fader turned fully counter clockwise & it's like it isn't there.
richardb, austin
__________________
__________________
- ksawatsky
Re: Removing Fader
Thanks, that was a help!Gary (Forum Admin) wrote:viewtopic.php?f=3&t=3192
I got the project done. For future reference (should someone search for this at some time in the future, here's the layout:
From amp (small connector) Front speakers -->Rear Speakers (I did not use)
Right + Red Red/Yellow Red/Blue
Right - Black/Yellow Red/Black Red/White
Left + Blue Blue/Red Blue/Yellow
Left - Black/Blue Blue/Black Blue/Green
Here's my new 12V socket replacing the Fader (Blue Sea -- rectangular plate is almost perfect size!)
Here's my new connector. I just cut the wires to the fader and crimped back together as noted above -- see the loop. I left enough wire attached to the circuit board so this could be reversed if I ever wish to do so. FYI, the circuit board in the fader has this clearly -- if a bit small -- noted as well.
Hope this helps someone!
Kevin Sawatsky, Caddo Mills, TX
IBA #487
2001 BMW K1200LT
IBA #487
2001 BMW K1200LT
Re: Removing Fader
Kevin, Did you notice a difference in sound afterwards ?
I got one thing to say, better burn out than fade away !!(highlander)
