Flasher Relay
vstarridin
Current bike(s): 1998 Vstar650 classic
1999Vstar1100 custom
Flasher Relay
Post by vstarridin »
Good Morning
Currently on the road and my turn signals/hazard lights have failed. I suspect the flasher relay has failed. Does anyone know if there is a substitute for the Kawasaki part. Maybe a NAPA part?
bikerking.biz
1970 Honda CL 350
Re: Flasher Relay
Post by bikerking.biz »
I think it's unusual for a flasher relay to fail, have you checked for the possibility of a blown fuse? I'm assuming that they are not turning on at all.
If it's not that, there is one listed on the dollar4dollar page.
Biker King
http://www.bikerking.biz
Re: Flasher Relay
get hold of a ( test light ) and pull the faux tank off, the flasher is on the left side attached to the battery hold-down . See if you have power there when in turn position of the switch.
mountainman
Re: Flasher Relay
Post by mountainman »
Try this, just wiggle your ignition key a little, and or push it in. See if this cause them to start working again. Then you will know if its the switch. Mine has done this from time to time and I squirt wd40 in key hole and its ok for a while.
1982 Suzuki GS750TZ (sold)
1977 Kawasaki KZ650 (sold)
1974 Kawasaki KZ400 (sold)
woodman
Current bike(s): 1998 Kawasaki voyager zg1200
Re: Flasher Relay
Post by woodman »
recently had the same problem. took it to a electrical shop Ended up being loose wire from ignition switch. you can check by simply jiggle the harness where it goes to the ignition switch. If it is it's not that hard or expensive it repair.
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Re: Flasher Relay
Post by gearheadfla »
Any of the 3 plug round flasher should work, get a heavy duty one that's for pulling trailers, that way if you add lights the flasher will still handle to load.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
David in NW Penna
Re: Flasher Relay
Post by David in NW Penna »
I use a Tridon EP-34. It is an electronic flasher unit. This is great if you've converted a lot of your lights to LED.
David & Linda in NW Penna.
1998 Voyager XII
Member AMA, AVA, EMC
