Removing headlight to access wires for GPS
- Current bike(s): 2003 Vulcan 1600 Classic
2014 Vulcan 1700 Voyager ABS - Location: Jackson, NJ
I'm going to be adding the Zumo 660 to the bike. The wiring adapter states to remove the headlight to gain access to the auxiliary wires located to the left of the radio. Can anyone tell me how to remove the trim and headlight? I have a 2014 Voyager. Thanks for your help!
- Current bike(s): 2011 Blue/Silver Voyager
Re: Removing headlight to access wires for GPS
There is a screw in the 6 o'clock position on the underside of the chrome trim ring and then 3 screws are holding the headlight in place.
Dave Smith
AMA, BK, CMA
AMA, BK, CMA
Thanks for the input. Do you know if there's anything else holding the chrome trim ring, like for aligning the chrome trim ring.
It just has two tabs if I remember correctly.
Dave Smith
AMA, BK, CMA
AMA, BK, CMA
The length of the wires they provide seems excessive, but I guess it's better to have too much than not enough!
I still have to buy a micro sd card so I can add music on the GPS. I've never done that so it should be a fun!
Jim Brophy
'14 Voyager Black / Gray
