need used front floorboard
allen321
Current bike(s): 1993 Kawasaki Voyager
Post by allen321 »
Looking for used floorboards to fit 1993 Voyager
chrisbfishin
Current bike(s): 1987 Voyager Xll
Re: need used front floorboard
Post by chrisbfishin »
Are you still looking for front floorboards? I have a set I took off my 87 this summer. There is also a heel toe shifter with them. They have mounting brackets and the boards themselves look identical to rear boards. You do have to modify the shift linkage for these, as the shifter mounts higher than stock. So you have to turn the shift lever over on the transmission shaft and adjust it. You will also have to modify the rear brake lever, as it has to mount above the right board. All the modifications are adjustments and an adjustment to the brake lamp switch. No fabrication needed. Nothing wrong with these boards, but they were too high for me, so I went back to stock pegs, shifter, and brake lever.
