First Oil Change
Godlover
First Oil Change
Post by Godlover »
Okay - I just finished my first oil change and did it by the book. I was reading through some past forums on oil changes and someone mentioned the washer that goes between the spring and the filter. I didn't see one when I changed the oil and didn't know about it. I assume it is stuck to the old filter that is in my garbage can. I will check tomorrow. Is this something I need to be concerned with? If so, can I just drop the filter - install the washer and re-assemble. If I do this - how much oil does do I need to put back in? Boy, I'm full of questions!!
debron
Re: First Oil Change
Post by debron »
Do you meant this washer?
That's a darn good question(s). I would certainly pull it out of the garbage until someone who knows responds.
Godlover
Post by Godlover »
debron wrote:Do you meant this washer?
I will have to dig out the old filter and see if it is stuck to it....
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
don"t panic. 95% of the machines i service are missing this washer. if yoiu find it just put it aside and install it on the next oil change. i have never seen a problem with machines with out the washer.............
:hpdc:
Nathan (South Carolina)
Post by Nathan (South Carolina) »
I think that the washer is there to keep the spring from tearing the rubber grommet on the filter. I had the same arrangement on my 82 Honda 900 Custom and accidentally threw the washer away with the filter. It ran fine for 16 years without it.
Lone Eagle
2001 Kawasaki Voyager XII
Godlover
Post by Godlover »
Guess I won't worry about it! Thanks!! :-D
Littlebeaver
Current bike(s): 1999 Voyager 1200, 1981 Honda Goldwing Interstate 1100
Post by Littlebeaver »
I just learned of this washer... Just did an oil change myself,, It was not present....Also when you go to get a filter for the machine's engine from the dealer, you have to get the O rings separate. :dm: ...All my other bikes came with an O ring, I assumed they would be in the box, crud... next go around it will get the washer and the new O'rings. #671 and #670 A o ring and the washer is 92022...Gosh darn it... :gig: Image :clap:
I've used the same o rings for several oil changes without any problems.
Buy a fram filter at walmart, comes with o rings
Has liked: 83 times
Been liked: 140 times
Every filter I've gotten (Walmart or NAPA) the boxes have had both O rings in them. Check other boxes before you go to the counter and pay, it may be that some SOB lifted the O rings out of that box.
kehnisz
Current bike(s): 2006 Burgman 650
Post by kehnisz »
K & N include the o-rings also.
K Ehnisz
Past Vice-President NorCal Voyagers 2012-2013
USCGR (ret)
2006 Suzuki Burgman 650
usmalenurse
2016 Honda Goldwing
Has liked: 7 times
Been liked: 41 times
Post by usmalenurse »
I've only used Napa filters in mine but always check before taking them home. My "local" store had one that was missing one of the o-rings as well. May have been sent from the factory without it but nonetheless I now check them out before I buy.
Charles Hairr
1997 Voyager XII
2016 Honda Goldwing
Littlebeaver
well thanks guys,, I did not know this.... My Honda oil filters always has them... I bet someone took them out of the box.. Very helpful comments... thanks....I just found the post with all the Aftermarket filters, holy smokes... I missed that one before,, Wow..Cool...lots of choices.... Probably get the Fram or Napa one next time.. Fram CH-6012 Napa 4941....
Been liked: 238 times
There are actually two different filter models: one with the O-rings, one without. My CB750, and my KZ440 both used the same filter as the XII, but I once grabbed the wrong filter, even though it was identical, sans O-rings... Had me worried, at first, but the bike ran fine with the old rings left in place. They looked to be slightly shrunken, but that was likely my paranoia coming through. :shock: Cheers!
debron
Post by debron »
I once forgot to replace that washer during an oil change and put the washer someplace safe and easy to find so I could reinstall it during the next oil. It was three more oil changes before I could find that darned washer! Sure enough, it was someplace where it should have been easy to find, I was just blind! Anyway, had no oil leaks or any other problems without that washer.
Littlebeaver, are you aware of our Dollar-4-Dollar page on the website that gives a lot of alternate parts and accessoroes info for all of the Voyagers? You'll find it here:
http://www.amervoyassoc.org/indexDollar4D.php
Littlebeaver
where in tarnation was this page hiding? :oh: thanks sometimes it helps if I actually look through some of these sections of this site... :gig: LOL
Neal
Tourer
Tourer
Post by Neal »
Wal-Mart doesn't sell our 6012 filter anymore :-(
debron
Post by debron »
Littlebeaver wrote:where in tarnation was this page hiding?
In plain site, I mean sight! :lol:
Has liked: 83 times
Neal wrote:Wal-Mart doesn't sell our 6012 filter anymore :-(
Both of the two local Wal-Marts near me still carry them, BUT they have moved them along with other motor-sports filters to the little area they call the Motorcycle section with helmets, gloves, goggles and such.
Next time you're in a Wallyworld look in that are, you might just find filters for bikes and ATV's hiding on a shelve there now!
kjsett
2009 Suzuki Vstrom DL650
Post by kjsett »
Not all Wally worlds are the same. Some older ones don't have the shelf space, so pickins may be leaner there. Also they have these new smaller versions they call "Fresh Markets" or "Neighborhood Markets" (can't remember if that is correct, but they built one near us, but they rarely have what i need so i don't go there). Just sayin that not all have all the same stuff (or as much variety). I did notice that section mentioned just last week but didn't explore it because of time constraints.
JMHO :thk:
Has liked: 83 times
Ken, if you get a chance to explore it don't blink - there isn't too much to it! I haven't come across any of the mini-WalMarts yet but I'm sure in time we'll have one or two planted here and there in PA also.
