For my '93; I cannot find the fork diameter in any of the forums Tech Tips or the service manual. I'm trying to figure it our so I can purchase the proper fork seal driver. Any assistance is appreciated.
~Steve
Fork Tube diameter question '93 Voyager
- HawkeSHR
- Current bike(s): 2008 Kawasaki KLR 650
1993 Kawasaki ZG1200 - Location: Perkasie, PA
- Guru
76 kz900 LTD
Re: Fork Tube diameter question '93 Voyager
you will need a 41mm driver, the motion-pro part number is 08-0123. i have used one of these for years on hundreds of voyager xii forks........carl
- HawkeSHR
Thanks Carlcarl leo wrote:you will need a 41mm driver, the motion-pro part number is 08-0123. i have used one of these for years on hundreds of voyager xii forks........carl
Or you can be inventive and buy an 1 1/2 PVC coupling, remove the butt ring on the inside of the coupling and you have a perfect fit bushing/seal driver. The coupling will side up/down on the fork tube with just a little clearance to spare. Tap the bushing & seal down.
- HawkeSHR
Thanks David!davidl wrote:Or you can be inventive and buy an 1 1/2 PVC coupling, remove the butt ring on the inside of the coupling and you have a perfect fit bushing/seal driver. The coupling will side up/down on the fork tube with just a little clearance to spare. Tap the bushing & seal down.
- Lance McCaw
Thats what I use ! Been using the pvc method for years.HawkeSHR wrote:Thanks David!davidl wrote:Or you can be inventive and buy an 1 1/2 PVC coupling, remove the butt ring on the inside of the coupling and you have a perfect fit bushing/seal driver. The coupling will side up/down on the fork tube with just a little clearance to spare. Tap the bushing & seal down.
