Rear Swing Arm Adjustment
Larry in Arkansas
Has liked: 2 times
Been liked: 6 times
Post by Larry in Arkansas »
I've replaced the swing arm bearings and in looking at the swing arm installation notes on chapter 12, page 12, it says to torque the adjuster nut T-4 to 13.0 foot pounds while holding the lock nut. Is this to set the preload on the bearings?
My reason for asking is that the last time I repacked the swing arm bearings some years ago, I was advised not to tamper with this bolt as it would affect the alignment of the swing arm.
Which is correct?
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Re: Rear Swing Arm Adjustment
Post by carl leo »
this is to set the preload, you only do this when replacing the bearings.. after torquing loosen the bolt and re torque to set the inner races.....
Larry in Arkansas
Has liked: 2 times
Been liked: 6 times
Thanks Carl. I thought that was correct.
