Front Brake Lockup (Solved)
customsound79
Current bike(s): 1992 Kawasaki Voyager XII
Post by customsound79 »
I couldn't find a solution to this with a web search I thought this might help someone. My front brakes were locking up after about 3 miles. I bled them and the problem persisted. It turns out some of the brake fluid crystallized and clogged the tiny return orifice in the master cylinder. Compressed air didn't clear it but I plucked a wire from a wire bush with needle nose vise-grips and worked it out. Problem solved.
Lucasind
and a bunch of parts !
Has liked: 200 times
Been liked: 69 times
Re: Front Brake Lockup (Solved)
Post by Lucasind »
....been also plucking a single hair from a wire brush over the years myself, the perfect fit to solve many problems ! glad it worked out for you ! tony :-D
Good repair, just what me and Tony would do. Ive been pluckin out strands of electric wire and wire brush's for years also.... :gig: great use's for paint guns to pilot drilling in carbs , and voyager master cyl's .....
