Hi all;
I have the same problem I hear other people have with the ZN1300...idle hard to set, bad gas mileage, etc. Seems one needs a Throttle Sensor Position Checker 57001-1003, and of course my local dealer doesn't have one, haven't seen anyone with one..
Does anyone have one of these? Do you know of anyone who does? Maybe a dealer willing to lend another dealer one, if not a home mechanic? Anyone with one to rent? Anyone who knows what is in it...looks like a simple wiper voltage reader with two LEDs, possible easy to duplicate.
I'm really tired of trying to set an idle and looking like a fool at stoplights. Any suggestions?
Throttle Sensor Position Checker TPS 57001-1003
- Current bike(s): 1984 Kawasaki ZN1300 Voyager
1984 Kawasaki GPz900R
1981 Yamaha XV920R - Location: Ottawa, Canada
- Lucasind
- Has liked: 194 times
- Been liked: 69 times
Re: Throttle Sensor Position Checker TPS 57001-1003
http://www.mrcycleparts.com/parts/kawas ... r-tps.html" onclick="window.open(this.href);return false;
https://answers.yahoo.com/question/inde ... 917AAiLQBi" onclick="window.open(this.href);return false;
These bikes are great ....but getting old , tough to find dealers with the parts and service capabilities !
here is some stuff to read or call for more info.
Thanks for the links.
I may have found a TPS checker...at BikeBandit...they have it listed for $159US, which is about million dollars Canadian, but we'll see, they may come back and say they don't have it. Crossing my fingers.
In the meantime, I sprayed the hell out of the TPS with electrical contact spray, played with it a bit and set it slightly counterclockwise from original position...seems OK right now, we'll see!
Just checked...BikeBandit closed the order...not available. So much for that route. The checker has to be a simple potentiometer reader, except with dumb LEDs instead of a voltmeter reading. If only someone would know the expected voltage at 1000 rpm, it would be simple to measure and adjust.
Any old timer mechanics out there?
- Been liked: 262 times
You can check it with a digital VOM .
here is a link to the service manual supplement for the 1300 Voyager
section 3 page 18
http://www.survivalring.org/myvoyager/f ... LEMENT.pdf" onclick="window.open(this.href);return false;
section 3 page 18
I think you're right...I have the manual and performed whatever tests I could before the bike was running, but there you are..expected readings. Thanks, I think you're onto something, MeAgain!
