Changed battery and starter engages when I try to connect neg post
Relics
Current bike(s): 1988 Kawasaki Voyager
Post by Relics »
Changed battery and when I try to install negative post; the starter engages and post really gets hot. Any ideas/ Thanks.
Furchin
Re: Changed battery and starter engages when I try to connect neg post
Post by Furchin »
my thoughts are that the battery is low on charge and the starter relay is hung up.
'96 Kawasaki Voyager
If you don't hear the starter clicking when you hit the negative terminal on the battery with the negative post your relay is hung up and constantly sending voltage to the starter. Tap the relay a few times with a wrench or the backside of a screwdriver and see if it frees up. If not replace the relay.
Relics
Post by Relics »
Problem solved. Starter relay stuck. Thank You for All replies.
krasmu
Been liked: 18 times
Post by krasmu »
Great news and we all got to learn something as well.
Kirk Rasmussen
Machesney Park, Illinois
