Cooling hoses
sgilbert14
Current bike(s): 1998 Concours 1000
Just purchased a 2000 Kawasaki ZG1200 Voyager XII for the spring
Cooling hoses
Post by sgilbert14 »
Need some ideas as to the best place to buy a set of new hoses, Finally got to hear the bike run for the first time since I bought it and as I let it get to temp it blew one of the 2 lower hoses. Great that it was in the garage and not out on the road, but now I need some hoses. Any input as to the best place to find them at a good price? :please:
kjsett
2009 Suzuki Vstrom DL650
Re: Cooling hoses
Post by kjsett »
I took the hoses I needed to Napa and they matched them up for me (had to cut to length though).
They also carry a correct Radiator Cap (but these should also work):
NAPA 703-1695
Prestone RR-27
Stant 10227
Motrad T-13R
TVS 1-227B
Gates 31333
CST 7513
Balkamp 703-4773
CARQUEST 33028
sgilbert14
Re: Cooling hoses
Awesome thanks so much...
Rhinestone Kawboy
1970 Honda CL350 Scrambler
1977 Carabela Marquesa 125 MX
Re: Cooling hoses
Post by Rhinestone Kawboy »
You can also find replacement hoses on the alternative parts & replacement category on the Dollar4Dollar page here:
https://amervoyassoc.org/indexDollar4D. ... PLACEMENTS
Iron Butt Member #47339
sgilbert14
Re: Cooling hoses
Thanks, I took a ride and went to autozone, advance and NAPA and came out with 3 hoses tonight. Seeing that I also wanted to replace the thermostat and one of the breather hoses I ended up ordering them from Partszilla for 120 plus ship. Spent a bit more than the auto stores but with driving the 40 miles round trip to get parts .. ugh. So, give it 3 days ship and I should be back together for the weekend... Thanks for all the help
Tonyvdb
1981 GPZ 550 (Previous bike)
Re: Cooling hoses
Post by Tonyvdb »
Use caution when just buying bulk hose cut to length. Some of the hoses on the XII have quite the bend to them and straight hose usually kinks when you try to force them in place. Its better to order the correct OEM hose (Yes Kawasaki still has them available) They are cut correctly and have the bends already in the correct spots.
sgilbert14
Re: Cooling hoses
I was thinking of the same thing. I picked up 3 hoses that had almost perfect matches in the bends. Went on w/o any bending at all. The rest I ordered from Revzilla and Bike Bandit
sgilbert14
Re: Cooling hoses
Wow, what an adventure in finding one of the houses. Turns out that Kawi is not longer making
HOSE-COOLING,LH
Kawasaki
item: 39062-1149
After a ton of calls to parts suppliers including Kawai warehouse I finally fond one at CHEAPCYCLEPARTS.COM. :woohoo: :woohoo: . In fact,unless their system never updates I ordered 2 just in case.. rep said that they showed 10 in stock.. wow not fun..
Re: Cooling hoses
A Google search showed that pn available at several dealers
sgilbert14
Re: Cooling hoses
That was how I started. I did a google search and then started calling dealers and was being told that it was no longer available from Kawai. I just kept going down the search list until someone said that they had it for me.
sgilbert14
Re: Cooling hoses ---- blowout #2
Blowout #2
I bought a house from NAPA to replace the one that blew and thought that will I am waiting for the new hoses to arrive I would put it back together and flush the cooling system. Put the cleaning in, got it to temp and it ran great for about 10-15 mins and then blew out right house above the engine... ugh.. well, at least I have not had it on the road when this happens...
Has liked: 852 times
Re: Cooling hoses
Are the hoses that rotten,that they are bursting,or do you by any chance have a combustion gas leak into the cooling system that is over pressurizing the system causing the hoses to fail.?I certainly hope that is not the case :cry2: but I have seen it in my 50 years of working on farm tractor engines.Try starting it up with the radiator cap off,after you replace the bad hose,and if you see bubbling out of the neck,there is a good chance that is the cause.
Re: Cooling hoses
Another possibility,is the radiator cap is opening at too high a pressure,and as the coolant warms up,and expands,instead of the cap opening to relieve the pressure,the hoses go instead. :thk:
sgilbert14
Re: Cooling hoses
Thanks. I have a new cap in the hose order as well..... Even though I added the flushing fluid and ran it through for the 10+ min's is would it be better to have the dealer flush it as well....
Been liked: 134 times
Re: Cooling hoses
sgilbert14 wrote:Thanks. I have a new cap in the hose order as well..... Even though I added the flushing fluid and ran it through for the 10+ min's is would it be better to have the dealer flush it as well....
Just my two cents, but in the 10+ min that you ran the engine , did the fan kick on. I have a 2000 1200 and in the 80k miles have never needed to let it run over 5 min to get it up to running temp. And wouldn't do it anyway as they heat up quick. Letting any engine get too hot is not a good thing .....In my opinion there isn't much need to chemical flush the newer engines, there is no cast iron to become scaled to that point of cleaning. As Loren pointed out , do check for combustion pressure into the cooling , and be sure to flush out all the chemical flush agent, if left in will attack gaskets and seals.
Another thing you may want to check , If anyone has done the fuel filter the way the manual describes, there is a risk of pinching off the coolant recover bottle hose when putting the fuel tank back in place , so even if the cap opens there is no place for the pressure to go. That along with the pressure cap can cause some hose bursting issues.
Gene K.
Re: Cooling hoses
... thanks for addressing the bursting hose issue, THAT had my head itching!!! GBG
I couldn't imagine what would cause hoses to bust!!!!
Re: Cooling hoses
Gene K.
Thanks,Gene,Pinching off the hose to the coolant recovery tank did not even cross my mind, :bat: ,but it is certainly a possibility, :hmm:
sgilbert14
Re: Cooling hoses
wow great info..
I out in a new fuel filter by pulling the fuel pump out while the carbs were away.. still, may have pinched off a hose or something..
Cleaning chems.. I planned on duck taping the hose that blew and just flush the system using a hose and nothing running.. so,, seeing that I have another week or so for my hoses I have some time to take things off and check out the houses for pinching..
Thanks everyone for the help :clap:
thrasherbill
Current bike(s): 1986 Voyager XII
2005 Z1000
1990 XT600E
2020 Indian Chieftain
Re: Cooling hoses
Post by thrasherbill »
I just ordered these hoses from my local Kawi dealer for around $50 for three (two lower, one upper) They were in stock in Kawi's Toronto warehouse (I'm just outside of Vancouver BC).
sgilbert14
Re: Cooling hoses
Awesome, I was able to get all of them, I hope that is. The hardest one for me to find was the:
39062D: HOSE-COOLING,PY-PASS 39062-1153
