if you have stubborn bolts and nuts heres what we used in the building trades.
#4)w-d 40 wd stands for water displacement not the best.
#3)pb blaster is good
#2)kroil for of the shelf its better
1#)50/50% mix of atf and acetone,buy a spray bottle make your own i carried this for 30 years on the job
winter work/penatrating oil
- Has liked: 902 times
- Been liked: 316 times
Re: winter work/penatrating oil
We like Kroil in our repair shop
We never tried the mix of ATF and acetone,but it sounds like we should try that also,as we often have some quite rusty equipment come in
I like Kroil when I can find it. Last time I had a stubborn bolt I used PB Blaster.
- 6
- Current bike(s): r100rt bmw
cush,
that transmission fluid/acetone is hand down the best.you can run a search it on top of all research.
im in vermilion.was a plural member with seville masonic lodge.good guys.
be safe
squirrel
be safe
squirrel
Sounds like a good mix Acetone/thin oil is a very thin solvent mixed with a thin oil. Now i know some may think this is off the wall, but I go right to the cleaning tank, scoop up some solvent from the tank that has cleaned and mixed with just about everything from dirty engine oil to trans / gear oil /diesel fuel and whatever has been cleaned off in the tank. Then with a acid brush I apply it to the area . The majority is cleaning fluid and is SO thin is seeps into the tightest, DRY and RUSTED AREA'S . Once it seeps in and has wetted the rust that usually loosens up the rust and out comes the fastener or shaft .squirrel wrote:cush,
be safe
squirrel
All that is needed is to wet the rust that has things bound up, and does not cost a dime. A old German foreman taught me this trick from before all these Bolt ease / nuts off and other canned products came about. He even used a few drops gasoline or kerosene to seep into tight spots. Old school tech trick
We should meet up sometime squirrel,I only live about 70 miles from you near Orrville.squirrel wrote:cush,
be safe
squirrel
