86 voyager xii carb cables
Danimus
6
Current bike(s): 1986 Kawasaki voyager xii zg1200-A
Post by Danimus »
I got a new carb for my bike but I can’t seem to get the decelerations cable back on the carb. It is to tight to get the cable in the bracket. If I move the toon it all the way down I can force it in but then the throttle can’t move. Any tips? Am I doing something stupid? Please help
squirrel
6
Current bike(s): r100rt bmw
Re: 86 voyager xii carb cables
Post by squirrel »
i dont own that model so take what i say with a grain of salt.
try putting the cable you cant get on first then try the one
you can get on.
if that doesnt work mark your threaded adj with felt tip
or paint stick so you can return them to original position then
loosen the adj install cables.then tighten adj to the position
you marked
start simple as in step one,then step two.and wait for
someone thats has the model to respond.
later
squirrel
squirrel
6
Post by squirrel »
danimus
check the tech sections /using the search feature.
there someone with the same problem.
squirrel
