winter work
Lucasind
and a bunch of parts !
Has liked: 198 times
Been liked: 69 times
Re: winter work
Post by Lucasind »
Hello all ! Last Sunday ,A rare 55 degree, sunny day in Feb. here in northern Ohio gave me the opportunity to test ride my latest Voyager to grace my workshop airlift for the past 3 months ! I took my van a hour north of Detroit around the end of November and got this one from its resting place in a guys garage for the past 3+ years ..... A very long list of issues kept me busy with this 87' .Fuel leaks from everywhere ! I musta had the carbs on and off this darn thing 5 times before it was right ! :tho: I didn't think it was possible for a Voyager to leak so many fluids ,from so many places ! The strangest one being BOTH counter-balancer shaft seals on the lower R.H. side had been leaking for many years,(never seen one leak from there before) along with the oil pressure sending unit leaking.....had the underside of this engine a filthy mess ! But ...one repair at a time , till the list was complete ....so I thought ....upon my ride last Sunday , the dash lights would flicker, then the turn sigs. wouldnt work without wiggling the key....so called our friend Carl for a new/used keyswitch,, installed that yesterday after work , and now I have the list completed except I would like to replace the stereo's "mute button" on the left handlebar ,(sprays didn't help much) I have a few of the rear passenger radio controllers in like new condition, in my parts cabinet , gonna rob a mute button from one of those and see if it will interchange. Now just waiting for Mother Nature to call for a end to cold and snow ....so we can go riding ! :thmup: ..........................Tony D. :-D
Has liked: 881 times
Been liked: 300 times
Re: winter work
Hi,Tony,Long time since we last communicated. :thmup:
I did not know you found another VXII. :clap: It must be giving you something to do in your spare time! :rolling:
How have things been going for you since Summersville?
Are you planning on going to the Rally in New Hamshire?
Lucasind
Re: winter work
Post by Lucasind »
......Hello Loren , same old stuff going on, I will send you a picture of the latest XII, ....not sure if we are going to NH this summer , likely not , as Florida friends are coming up to Toledo that week, gotta return the hospitality that they have shown us while visiting FL.......... :-D
Re: winter work
Tony,if you don't,we should make plans to find some fish somewhere :thmup:
Then get caught back up on news. :woohoo:
joelcolletti
Current bike(s): 1994 Voyager XII (purchased new from California Kawasaki's showroom floor)
Has liked: 7 times
Been liked: 7 times
Re: winter work
Post by joelcolletti »
Hi Tony, I'm interested in finding out how you repaired the leaking Gear Balancer. I noticed I have a slight trickle of what I'm assuming is oil, being pushed, from the front / right sealed bearing. I read on these boards, the bottom end on these machine don't leak, so I'm wondering - Is this likely going to need a tear down; has anyone had this happen and had the repair made?
Miles of Smiles :0)
Re: winter work
I never had a leaking balancer shaft, :hmm:
I have had oil leak out of the water pump,but a new seal held in with blue locktite fixed that :thmup:
Tony,aka, Lucasind had the balancer shaft seal leaking.
joelcolletti (Tue Jul 14, 2020 10:28 pm)
joelcolletti
Has liked: 7 times
Been liked: 7 times
Re: winter work
cushman eagle wrote: Tue Jul 14, 2020 12:42 am I never had a leaking balancer shaft, :hmm:
Sorry / Thanks for the 411
Miles of Smiles :0)
Has liked: 493 times
Been liked: 444 times
Re: winter work
joelcolletti wrote: Tue Jul 14, 2020 10:38 pm
cushman eagle wrote: Tue Jul 14, 2020 12:42 am Tony,aka, Lucasind had the balancer shaft seal leaking.
Gene Kap explained to me that the balancer shaft leaking is usually caused by using a high-pressure car wash nozzle in the vicinity of the balance shafts. It forces dirt and junk into the seals.
joelcolletti (Thu Jul 30, 2020 3:08 pm)
2008 Ford CVPI
SJ Retreads, PGR, WWR
joelcolletti
Has liked: 7 times
Been liked: 7 times
Re: winter work - Gear Balancer Shaft Seal Leaking = Death Sentence?
I hope You and Your Loved Ones are making it through this difficult time and Pandemic - Please stay Well!
Thank you so much for posting: That's really good to know! Thank you for passing along that valuable information on the balancer shaft seal. :perfect10:
In the 26 years I've owned this bike, right from the showroom floor, I never put a garden hose to it nor a power washer. The seeping just came from out-of-the-blue. I noticed the weeping, after taking off my floor boards and heel toe shifter for zipping around the twists here, since I haven't doing any long distance riding the past 5 years or so, since HMB Don and Thrisa left for their new digs.
I read using Loctite or super glue could be a work around, but one shop said it will either work or blow out. Not sure if anyone has a cure for my machine.
I called some "5 Star" Yelp cycle shops nearby, and am hearing 25 hours @ $150 per hour to remove the motor and split the casing; The place I'm considering quoted 25 hrs for $3500 just for labor; with work to start in October. Most places didn't want to take the project on.
I was going to post a separate thread for this matter for some ideas, and to find out if "25 hours" sounds right from Folks-in-the-know.
I was thinking/hoping it would be more like 10 hours. I'm pretty sure they know better and wouldn't want to rush a job like this. A lot of places, here, don't want to touch the bike b/c of its age. Fortunately, there are still plenty of parts out here, and I keep up the bike, so some shops will make an exception occasionally. I don't want to alienate this shop that quoted me for an October tear down.
I've saw an engine parted off of a 2001, with approximately 50,000 mile on it for about $800 on Ebay. This would seem smarter to me, but I have about 60,000 on my machine, and starting to have problems. Reminds me of when I replaced my 76 VW Rabbit motor when I was 19. The dealer's chief mechanic sent me to a wrecker for a working motor. Long-story-short, that engine wouldn't start; I had to buy a factory rebuilt afterward.
Then, I though I could drain the bike, take it off the battery, and keep it as an expensive die - cast model 1:1 scale :-D , which by the way, there isn't any other scale Voyager Xll die cast to be found anywhere. I will want to have a die cast Voyager Xll if I can't keep riding mine any longer.
The shop said riding the bike with the balancer shaft seal leaking, could be dangerous leading to the seal blowing out and spraying my tires with oil. I thought the bottom end was fairly low compression on this machine - is there that chance? In a way I guess I should consider myself lucky to find out before setting off cross country.
Is my couch on wheels done for, or is it worth anything with the needed repair, say to someone like mechanic or someone with expertise, time, patience?
I hate to part with this bike or part it out, as I'd expected to be buried on it.
So many questions: I feel Like I'm losing a Loved One
What would you Folks consider doing?
:please: :help:
Miles of Smiles :0)
Re: winter work
.. what if ya assume it won't blow out, put a diaper on it and add oil as needed?
Easy works for me... Ya might check the "other" Kawasaki site, VROC.org for (Vulcan group)
fixing oil leaks, there have been cases, and of course, I don't remember any,
sigh.... Bet ya can find some sticky sealant that will do the job, and of course,
I have no idea where the repair is or what is involved.... Very Best to Ya!!!
joelcolletti
Has liked: 7 times
Been liked: 7 times
Re: winter work
Thanks Cranky- I Really Appreciate Your feedback. :idea: I kind of have a diaper on it now-when the engine cools, but the pipes get too hot to leave it on. I'll check out the VROC Folks site like you suggested. I'm keeping my fingers crossed for a non invasive sealant type solution if there is one out there. :thanks: :thewave:
Miles of Smiles :0)
wyofisher
Current bike(s): 1986 Kawasaki Voyager XII
Re: winter work
Post by wyofisher »
Actually the balance shaft seals aren’t that bad. Mine took to leaking last week. I just changed them, took about an hour, and I wasn’t rushing. Took off the brake pedal, and peg. Loosened the oil line clamp, as the bolt looks trapped by the exhaust. Remove both oil line banjo bolts. Took off the balance shaft clamp, the shafts can spin easily after this. Punctured the middle of the seals with a nail, to let me get my cotter pin hook engaged. Lightly tap the cotter pin hook in and Bobs your uncle. Then just install and lightly tap it in to seat with a socket.
Why do all my photos load upside down and out of order? I even flipped them over in my photo editor, but same result...
These users liked wyofisher's post:
cushman eagle (Sun Aug 16, 2020 2:38 pm) • tunnelz (Mon Aug 17, 2020 12:03 am)
wyofisher
Re: winter work
Post by wyofisher »
Now it’s bath time for my therapist (bike). Sorry, one or more grasshoppers may have been injured in the making of this mess.
