Flasher relay
- Current bike(s): 1984 Kawasaki Voyager
1974 Kawasaki Z1 900
1980 Kawasaki KZ750 LTD - Has liked: 0
Flasher relay
I recently bought a 1984 Voyager 1300 Six with a bad trip computer, compass controller, and a hazard flasher issue. The flasher turns the front and rear signal lights on, but they do not blink. The regular signals blink just fine. I figured the problem is the hazard flasher relay (which I guess is separate from the signal flasher?), but I cannot seem to find it on the bike. The base manual says to remove the tool tray and battery, but this bike has the EFI controller on top of the battery. Does anyone know where the flasher relay is located?
Re: Flasher relay
BTW I replaced the trip computer and compass controller and they seem to work fine now.
- Van Voyager
- Has liked: 46 times
- Been liked: 40 times
Re: Flasher relay
By 'replaced the trip computer' do you mean: you replaced the 'module' on the tank? Do you know what was wrong with the old one?
Re: Flasher relay
Yes, I replaced the computer module on top of the tank. I don't know what was wrong except that it did not display any of the mode indicators and had a value in the mileage display but would not clear. I found a used one on Ebay.
