- Deep Thoughts
- Has liked: 7 times
- Been liked: 23 times
- Has liked: 852 times
Re: Throttle cable splitter/junction box question.
Hi,Deep Thoughts,I do not think my PMs have been getting through to you,so I tried again
- Deep Thoughts
- Has liked: 228 times
- Been liked: 602 times
I couldn't help but notice this tidbit on page 2-5 of the manual:
"Do not disassemble the junction box of the accelerator cable assembly. Disassembling the box may upset the cable joints and cause the cable malfunction."
- Been liked: 134 times
Have you found a cable set yet ?
I may have a few used ones here in NJ.
Gene
Gene
- Deep Thoughts
- These users liked Deep Thoughts's post:
- cushman eagle (Thu Jul 14, 2022 10:23 pm)
- Deep Thoughts
- triton28 (Thu Jul 14, 2022 9:41 am) • cushman eagle (Thu Jul 14, 2022 10:23 pm)
- Deep Thoughts
- Deep Thoughts
- Nails (Thu Jul 14, 2022 12:28 pm) • cushman eagle (Thu Jul 14, 2022 10:23 pm)
Thanks for exploring this.
Was it difficult to identify the faulty cable without seeing it? I assume this is one of the throttle cables, and it either wouldn't open or wouldn't close right.
And can you speculate what problem the two-spring design solved? Was it to tolerate some conflict between the actuator and the throttle (such as in the hands of a rider who forgot the cruise was on)? Or maybe to tolerate some cable stretching? Or maybe a safety thing to allow closing the throttle no matter what?
- Deep Thoughts
- Deep Thoughts
- Deep Thoughts
- Deep Thoughts
- cushman eagle (Thu Jul 14, 2022 10:24 pm)
- Deep Thoughts
- Deep Thoughts
Wow. Wore out at both ends at the same time.
Thank You Very Much,Deep Thoughts,for your pictures and explanations of the cable splitter.
I never took mine apart,but just replaced all my cables during "winter service' a couple years ago.
Way To Go on rebuilding the unit
- Deep Thoughts (Tue Jul 19, 2022 6:32 am)
What I don't see in these photos is how the carburetor accelerator cable attaches to the junction box schtuff. I assume it attaches to the middle cam. Does it attach next to the pin affair -- hidden under the pin in most photos?
