Radiator
Conrad
89 yamaha venture royale
Has liked: 27 times
Been liked: 62 times
Radiator
Post by Conrad »
So is there some magic words to get the wire out from under this tab? It doesn't look like the plug will fit through, and i can be a bit ham-fisted, so I'm hesitant to just pry it up and chance tearing the rivet out of the lower tank...i want to bring the radiator to a shop to flush and pressure test, but not with the fan and wires on it.
Thanks!
Conrad
Has liked: 27 times
Re: Radiator
Post by Conrad »
Bump...
Been liked: 108 times
Re: Radiator
Pry it open with little flat screw driver then when you have clearance use a small needle nose plyers to open it.
Take it slow. It will open up.
Conrad (Wed Feb 21, 2024 4:41 pm)
Conrad
Has liked: 27 times
Re: Radiator
Post by Conrad »
Thanks! All that thin aluminum just seems so...delicate.
Conrad
Has liked: 27 times
Re: Radiator
Post by Conrad »
Got it apart fine, thanks again! I've broken so many little tabs and such over the years i tend to hesitate.
cushman eagle (Sat Feb 24, 2024 3:48 pm)
