too good to be true???
Has liked: 114 times
Been liked: 289 times
Has anyone purchased the rotor/pad set from the link below and if so how have they worked out?
https://www.ebay.com/itm/296006715785?f ... SwQbllOSDA
Has liked: 234 times
Been liked: 621 times
Re: too good to be true???
Amazing, how many products they sell on Amazon and how few reviews are listed -- mostly with no description. Lots of 1-star "don't fit" and a few about incomplete package received. But from my 15-minute research, really no info out there at all.
Conrad
89 yamaha venture royale
Has liked: 27 times
Been liked: 61 times
Post by Conrad »
I bought a speedo cable the same brand, figuring i only got a year out of the motion-pro before it. It fit ok, we'll see how long it lasts... :thk:
Has liked: 491 times
Been liked: 444 times
Conrad wrote: Fri Jun 28, 2024 10:20 pm I bought a speedo cable the same brand, figuring i only got a year out of the motion-pro before it. It fit ok, we'll see how long it lasts... :thk:
Did you grease the speedo cable occasionally?
2008 Ford CVPI
SJ Retreads, PGR, WWR
Conrad
Has liked: 27 times
Post by Conrad »
Yup. It was plenty oily.
Interesting. The usual cause of failure is lack of lubrication. Did you replace the entire cable and housing or just the inner cable? If just the inner cable, then that would indicate a damaged housing (sheath). When you greased the cable (grease, not oil) did you use a waterproof grease? Did you go sparingly on the bottom couple of inches of the cable? The rest of the cable you grease the snot out of, lots of grease. Any excess will come out the bottom as you feed the cable into the housing.
2008 Ford CVPI
Conrad
Has liked: 27 times
Post by Conrad »
Yup, white lithium. It broke right at the first bend behind the wheel, the same place the previous one had. Maybe a routing issue. This time I put a bit more of the slack into the fairing, so a little less sharp bend by the wheel.
Oh, the sharp bend, yep, that'll do it. Shouldn't be any sharp bends at all.
2008 Ford CVPI
So NOBODY has any experience with these NICHE Front Brake Pad Rotor Kits? Did they just pop up out of the dirt, making a zillion different kits for a slew of bikes? Weird.
biguns
Current bike(s): 2000 Voyager,1980 Goldwing
Has liked: 9 times
Post by biguns »
I cant find anything bad about the rotor kits seems legit here is their website.
https://nicheindustries.com/collections ... oyager-xii
TJSki1985
Current bike(s): 1989 Kawasaki voyager xii
Post by TJSki1985 »
I am running these pads and rotors on the front of my 1989. For the price I really don’t have high hopes but they stop decent. I don’t really have a stock stopping power to compare it to. However for the money, if I get a year out of them, I will be happy. I have only driven about 500 miles on them so far. Seem nice.
These users liked TJSki1985's post:
triton28 (Sun Jul 21, 2024 9:55 am)
