Carburetor Reassembly
Et1sw47
Post by Et1sw47 »
Ok... I had to take my carbs apart because of a bad O-ring on the Tee where the fuel comes in. I decided to go ahead and replace all the O-rings.
My question is, what kind of lube, if any, is best to use to reinstall the O-rings?
I have dielectric grease, pool O-ring grease, synthetic motor oil, and slick 50 grease. Would one of these be fine or should I consider something else? :hmm:
Also, I assume I should NOT put anything on the plastic washers on the choke slide. Is that a correct assumption?
Thanks!
Avidrider62
Tourer
Tourer
Current bike(s): Bikeless
Re: Carburetor Reassembly
Post by Avidrider62 »
Call Carl, he'll give you the best answer 731-413-8666
2003 with 87 colors
Et1sw47 wrote:Ok... I had to take my carbs apart because of a bad O-ring on the Tee where the fuel comes in. I decided to go ahead and replace all the O-rings.
Thanks!
put a drop of oil on them and call it a day
