oil change
- Current bike(s): 1998 gl 1500 SE 2002 voyager xii
oil change
Is the filler cap under the left chrome carb. panel? How do you read the level? Very new to voyagers xii always been a Goldwing man,hope you can help a brother in need. Thanks
- Highway Rider
- Webmaster
1978 KZ650 D1 SR - Has liked: 158 times
- Been liked: 40 times
Re: oil change
Yes the filler cap is on the left hand side. Put no more then 3 quarts 22oz of oil in. that is if you remove the filter and drain both of the oil plugs on the bottom of the oil pan. the only wrench you need to remove the filter and drain plug is a 17mm. Also many of use use Shell Rotell 15/40 dyno oil. Non synthetic
Re: oil change
Thank you ,I was not sure because it had no dip stick.I use Delo 400 15w40 in my wing so I will move it over to the voyager also.
- Has liked: 890 times
- Been liked: 313 times
Re: oil change
There is a sight glass on the left side near the bottom of the engine,but the bike has to be level to read it consistantly.If it is not level,it will not be accurate.I set mine on the centerstand and have a place in my garage that sets it level,and check it about every 2000 miles.If it is level 3 qts 22oz has the oil in the sight glass just above the center.I check it for level with a carpenters level on the luggage rack.At least it is not as hard to find a level spot for the bike, as for our trucks with 3 foot long oil pans where being off level can make the dipstick inaccurate by +or - 6 quarts
- krasmu
- Been liked: 18 times
Re: oil change
drain all the oil using both plugs and the filter. place it on the center stand and trust the 3qt 22oz amount. let it settle out and then read your sight glass. Use this visual as a visual indicator for quick oil level checks between oil changes. I switched to Rottela T on this last change and was amazed at the difference it made in shifting and engine sound.
Kirk Rasmussen
Machesney Park, Illinois
- Current bike(s): 2003 1200
Re: oil change
Here you go again- READ IT
https://onedrive.live.com/?cid=25f882b6 ... CA8D%21173" onclick="window.open(this.href);return false;
wsm 1 wrote:Is the filler cap under the left chrome carb. panel? How do you read the level? Very new to voyagers xii always been a Goldwing man,hope you can help a brother in need. Thanks
Re: oil change
The only time you should have to access the oil filler cap is during oil changes. Use the right size phillips to remove the cover. Be careful pulling the 2 peg mounts on the cover from their rubber mounts. It is easy to break them. If you put the right amount of oil in the bike you should never have to check the level unless you know for sure it is burning oil. Check for oil residue on the exhaust pipes if you don't know. Good luck.
