Where's the turn signal flasher?!?
NSASarge
Been liked: 6 times
Post by NSASarge »
I had some cheap Chinese LED lights for my front and rear turn signals and, although they flashed a bit faster, they did work. Well, at the Hurley Rally, one of the rear LEDs burned out, so I went to WallyWorld and bought a set of 4 replacements. The front signals are also running lights (dual filament) and they worked just fine, but, as soon as I put the new (single filament) LEDs in the rear ... nothing! I really don't want to install an LED "load equalizer" because that defeats one of the purposes of installing LEDs. So, the next thing is to install an electronic flasher unit. This will flash the LEDs at a proper rate without the need for a "load equalizer". OKAY! So Where is the silly thing and, I'm hoping, can it be replaced with a "normal" electronic flasher, OR is it a proprietary Kawasaki configuration flasher?!?
:corn:
Ride Safe
Shoot Straight
Speak the Truth
David & Deb
"NSASarge"
2010 Voyager
AVA: 6178
AMA/ROK: 3308207
AAA: 620111405125201
Patriot Guard Rider
Retired US Army MI
Retired Thomas Built Bus
Retired
kjsett
2009 Suzuki Vstrom DL650
Re: Where's the turn signal flasher?!?
Post by kjsett »
I think it is under the faux cover, left side, close to the positive terminal of the battery. That is just memory, not a sure thing. I am sure someone else will chime in with a better answer if i am wrong.
:tired: :corn:
Boy, must have been tired. Thought you were asking about the 1200. :bat:
You're right, however it isn't labeled. It is one those three pinned together next to the battery left side. I cannot tell which one.
NSASarge
Been liked: 6 times
Post by NSASarge »
Mr Jensee wrote:You're right, however it isn't labeled. It is one those three pinned together next to the battery left side. I cannot tell which one.
Yep. I shudda been clearer. I know it's near the battery and is one of those relays, however, the dealer isn't much help. They want me to bring it into the shop so they can find it to help me. NOT GONNA HAPPEN. Not at their hourly rates! Guess I'll have to investigate some more. I'll keep posted.
:thk:
Ride Safe
Shoot Straight
Speak the Truth
David & Deb
"NSASarge"
2010 Voyager
AVA: 6178
AMA/ROK: 3308207
Patriot Guard Rider
Retired US Army MI
Retired
Unplug them one of the three at a time while the bike is running. Chances are your turn signals though they may no blink will go dead when you get to the right one.
