this is my first belt driven bike.
the belt is traveling from side to side inside the rear sprocket. Is this a problem?
belt traveling in rear sprocket
- Current bike(s): 2012 Kawasaki Voyager 1700
Re: belt traveling in rear sprocket
Have you checked the tension yet? Typically they run very tight from the factory.
Mine is usually running to the outside of the rear pulley which is normal.
- NSASarge
- 12
- Been liked: 6 times
As mentioned in other posts, the factory belt tension seems to be too high. This has caused the transmission output beating to wear and may be the cause of your belt "wobble". I would suggest you put your bike up on a lift and turn the rear wheel by hand and observe the rear wheel/sprocket to watch the belt "wobble". At the same time, watch the output to see if it "wobbles" too. Could also possibly be rear wheel "wobble". Keep an eye on possible rear wheel "run-out". Then take it to the dealer unless you can find the problem and fix it yourself.
Ride Safe
Shoot Straight
Speak the Truth
David & Deb
"NSASarge"
2010 Voyager
AVA: 6178
AMA/ROK: 3308207
AAA: 620111405125201
Patriot Guard Rider
Retired US Army MI
Retired Thomas Built Bus
Retired
Shoot Straight
Speak the Truth
David & Deb
"NSASarge"
2010 Voyager
AVA: 6178
AMA/ROK: 3308207
Patriot Guard Rider
Retired US Army MI
Retired
