Any ZN1300 guru's in the Atlanta area? I can't get the beast to start and looks like I have a 23 error code. Not sure where to start. I have the manuals, but when I try the quick tests the fuel pump keeps running when I unplug the starter solenoid plug.
I have a feeling its either the solenoid, relays or injectors.
Help.
ZN1300 Guru wanted
- Current bike(s): 1988 ZN1300
1982 GL500i - Location: Powder Springs, GA
Re: ZN1300 Guru wanted
I did a test and it failed the Electronic Speed test. What does this mean? The book doesn't explain what to do if you fail one of their tests.
Thanks
Thanks
