Clarion CB Radio Repair Procedures
- Nathan (South Carolina)
When sending the CB radio to Clarion for repair, do you have to send every component or can you send just the main unit and the CB controller unit on the fairing? I lost my channel display on the CB controller and the unit quit transmitting.
There is a click when the push-to-talk button is depressed but the TX does not light up. It does receive however and change channels but with no display, it is not possible to know what channel the unit is on. The back lighting on the unit also works. Anyone experienced this problem before?
Lone Eagle
2001 Kawasaki Voyager XII
Re: Clarion CB Radio Repair Procedures
Don't know about the Clarion part of the question, but my CB did something similar a few months ago. I took the hot battery lead loose for a minute and when I reconnected it, the CB was working again. Hasn't acted up since. I think the "processor" in the CB got hung up and removing all the power reset it. There is a "keep-alive" voltage going to the CB so it will remember what channel you were on when you shut the bike off. Just turning the CB off doesn't reset the entire unit.
You will have to reset the clock and presets on the AM/FM radio, as well, when you take the power off.
Hope this helps.
Hope this helps.
- Me Again
- Been liked: 282 times
Rick is correct.
90% of the time just disconnecting and reconnecting the battery will restore the display.
Thanks, I will try that!
Lone Eagle
- WingNutLori
- Current bike(s): 1990 Honda Goldwing GL 1500
If that doesn't work out for you...
Take your display unit to your local Kawasaki dealer. They will send it in to Clarion. Since they may need to ship other parts as well, talk to the Kaw dealer first. You can no longer send units directly to Clarion. They must be sent through a dealer.
I want to live my life in such a way
that when my feet hit the floor in the morning,
Satan shudders and says...
"Oh crap... she's awake!"
1990 Honda GL1500 - Burgundy/Gray
http://www.keystonewings.org" onclick="window.open(this.href);return false;
mine did the samething and one of the guys told me to remove display unit and check wire plug ins inside of unit , one must have been loose , it has worked ok since....jack
Lone Eagle
Glad it was the simple fix, Nathan. That always makes me feel good..
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
It's now in there! Voyager XII section of AVA Tech Center.Nathan (South Carolina) wrote:Thanks to all who replied. Disconnecting the battery worked!
Everything works now. Gary, you may want to add this information to the Tech Section.
Iron Butt Member #47339
