ISO Heel toe Shifter For driver floorboard
micheal_985
Current bike(s): 1987 Kawasaki voyager 1200
Post by micheal_985 »
I am trying to locate a Heel Toe Shifter lever for a Voyager 1200 With Driver Floor boards.
Micheal985
1987 Voyager Xii
Re: ISO Heel toe Shifter For driver floorboard
... never been there, but I have floorboards and a H/T shifter, put your search in a
Google search window and it led me to a path i AVA... FWIW
Re: First look, Rider floorboards and a heel-toe shifter?
by SgtSlag » Fri Nov 13, 2015 8:01 am
If you did not feel good about it, then you did what you needed to do: you walked away from it.
As far as the bike goes, I would say it likely was a very good deal. The engines, if well maintained, are bulletproof. They will go 200,000-300,000 miles with routine maintenance, if taken care of properly. The heel-toe shifter is still available off of e-Bay: drill two holes into the OEM shift lever, screw the new lever to the old, and done. The driver's floorboards could always be replaced with OEM pegs -- Carl Leo can help out with needed parts, his contact information is on this site, usually near the top of every forum listing.
micheal_985
Do any one have a heel toe shifter level for a voyager 1200 ,with running boards, for sale. I have the floor boards but I need the shifter Level. Micheal.
micheal_985 wrote:I am trying to locate a Heel Toe Shifter lever for a Voyager 1200 With Driver Floor boards.
Micheal985
1987 Voyager Xii
I knew something was in the back of my head, rumbling around about this...
At the home page is a tech index, one of 'um is Dollar 4 Dollar, and this is in there...
HEEL & TOE SHIFTER VOYAGER ZG1200
Heel & Toe Shifter Cut from 1/4" 6011 Aluminum Does Not change current RIDER foot position. You must drill 2 holes in your existing Shift lever, can be drilled on or off Bike. Available Pictures on eBay. Buy for $39.99 plus $7.99 shipping in Motorcycle parts for sale just SEARCH Voyager ZG1200 Heel & Toe shifter. Contact: fjjackson3@netscape.net
Has liked: 119 times
Micheal_985;
Contact Carl Leo at: voyagerparts@bellsouth.net
He may have one in his used parts inventory.
micheal_985
I have the add on heel shifter but I am not sure if it will work with the Floor boards? The way it's made I think it'd for the regular foot pegs. I really want the one that come with the floorboard kit it looks better. :-D
I sent a message to Carl Leo!
Thanks for all the advice!
Micheal
HMBTrisha
Current bike(s): 2007 Gold Wing trike
Been liked: 6 times
Post by HMBTrisha »
Look at the inside cover of this last issue of the Voyagers Voice. This heal and toe shifter is an add-on, that was hanging on Carl's used parts wall. The floor boards are Marvella"s floorboards which are very rare.
Good Luck
Trisha Blue
HMBTrisha
2021 CanAm Spyder RT Limited
