What's unde the ECU?
Van Voyager
Has liked: 52 times
Been liked: 44 times
Post by Van Voyager »
Can anyone post a picture of, or describe what's under the ECU. On mine a PO has inserted a plastic (like a thin cutting board) shield between the bottom of the ECU and the top of the battery (to prevent something from shorting against the battery terminal ???). Is there supposed to be a tray or something else there?
86 Voyager 1300
Me Again
Been liked: 282 times
Re: What's unde the ECU?
Post by Me Again »
That is exactly what it is for .Keeps the ECU from hitting the battery
Van Voyager
Has liked: 52 times
Thanks for your note MA.
Is is supposed to look like piece of loose cardboard (albeit made of plastic)? The one I have seems to have a 'homemade' quality about it and isn't attached to anything.
I'll be getting it out for the spring in another 6 weeks or so; will try to post a picture then.
Me Again
Post by Me Again »
Originally there is nothing in between but as the rubber holders deteriorate many have put something between to keep the battery and ECU from hitting each other
I have an oversized battery and put a thin piece of Styrofoam in between
Van Voyager
Has liked: 52 times
Thanks. That make sense. My rubber isolators had completely deteriorated and were held together (what was left of them) with duct tape. I was pleasantly surprised to find they're still avaible from Kawasaki so I ordered a set. I may yet regret that as it was a lot harder to get the ECU 'installed' with the new rubbers than with the old set. :roll:
Lucasind
and a bunch of parts !
Has liked: 203 times
Been liked: 72 times
Post by Lucasind »
....still have the Kawasaki part #'s handy ? I need a set also ....save me the time of looking them up ....... :-D
Van Voyager
Has liked: 52 times
Lucasind
Post by Lucasind »
:thmup:
