Battery Idiot Light
RDW-B14
Current bike(s): '12 KLR 650
'00 Voyager Xll -- For SALE!!
Battery Idiot Light
Post by RDW-B14 »
I'm changing the water battery to AGM. The salesman said put the idiot light wire to positive post to make the light go off. I've not installed it yet. Does the light stay on if not powered? If it does, isn't there a way to unplug the light instead of hooking it to power?
Thanks for your help!
Take care, RD
If one rides as one lives, would one be in the ditch?
'12 KLR 650
Has liked: 83 times
Been liked: 140 times
Re: Battery Idiot Light
That light is only lit when the bike is running. There are a few ways to cancel out the light, I have been running AGM batteries for about 6 years and still haven't cut/spliced my wire yet. I just ignore the light. I know what it is and why it's lit, of course it screws with others when they look at the dash while it's running! :rolling:
Has liked: 83 times
I did a quick search, easy this time since I knew what and who I was searching for! The message below was from a post a few years ago, but still stands strong!
Chris near Kansas City wrote: Fri May 13, 2016 2:19 am The battery light is nothing more than an electrolyte level sensor in the battery. Comes on when the water level is low. Put a voltmeter on it when running to verify any issue with the charging system. But you'll need to put some distilled water in the battery, or replace it with a new one. Most have gone to gel or AGM style that has no provision for the sensor. Clip the sensor off, and attach it to the orange wire on the turn signal relay, if I recall correctly. That'll keep the light turned off and not back-feed the system with the ignition, unlike if you hooked it directly to the positive side of the battery.
RDW-B14
Post by RDW-B14 »
Good to know! Thanks for your time and info.
Take care, RD
'12 KLR 650
RDW-B14
Post by RDW-B14 »
So, I cut the bullet terminal off the battery light wire and put on a spade. Then pushed it in with the orange wire on the turn signal flasher. Battery light off! Good deal, thanks!
Now, talking about the flasher. Is there a way to disable the automatic turn signal canceler so I can control them manually?
Also, do you really have to have the ignition ON to use the 4 way flashers?
Thanks, Take care, RD
'12 KLR 650
