Cam chain tensioner adjustment
DennyG+
Current bike(s): 1993 VoyagerXII
Post by DennyG+ »
I have a '93 with 45000 miles on it, and after reading about lifter noise and cam chain noise I think I have both. I am familiar with the lifter, or tappet, noise and it isn't too bad. What I am hearing now mainly is cam chain noise, I believe. After looking in the service manual and at the photos posted by Triton28, I understand more about it. The posts relating to it either say take it out and reset it, or basically ignore the noise. But, I haven't seen where anyone adjusts it by inserting a small screwdriver in and adjusting it while it's on the bike. Does anyone know if this can be done? Thanks.
Has liked: 105 times
Been liked: 273 times
Re: Cam chain tensioner adjustment
No Denny the slot is ONLY for reinstalling the adjuster into the cylinder block. It has no bearing on adjustment as adjustment is automatic.
DennyG+
Post by DennyG+ »
OK. Thanks for the info. I wonder why there are so many complaints of cam chain noise is it supposed to automatically adjust. Does it get hung-up?
DennyG+
Post by DennyG+ »
I meant IF it is supposed to automatically adjust
If you think you have abnormally loud tappet/chain noise then I would suggest reading a post entitled "Engine Noise" from June 06, 2016 posted by barefoot, in this section "Tech Tips-Voyager XII". In this post is a formula posted by Neal which uses ATF as a cleaning agent. It may clean the valve lash adjusters, and the rest of the engine internals for you.
With respect to the tensioner, the only 2 ways it can malfunction are: 1) the spring is getting weak or 2) someone has had the tensioner out and did not pretension it before re-installing it. These really are bullet proof and rarely malfunction but I'm sure it may have happened to someone's engine.
Has liked: 852 times
DennyG , If the oil level is too high,it can get air bubbles churned into it by the spinning shafts ,which can prevent the adjusters from working properly. :hmm:
The recommended volume,after draining both drain plugs and the filter is 3 qts 22 oz.
There have been many complaints of lifter noise with too much oil :thmup:
Let us know what you find out.
DennyG+
Post by DennyG+ »
Thank you all for your kind and sage advice. I recently changed the oil and put the correct amount in. Before changing it, I drained out a quart and put in about 6 oz of sea foam and the rest ATF and ran it for about 35 miles. The lifter sound got quieter, but it seems the other (cam chain) got louder. I use rotella 15/40. I'll just run it a while longer and see how it goes. Thanks again.
.. as I'm apt to say... I do NOTHING quite well!!!! GBG Best
to ya!!!
