Front Fork Allen bolt at end
- Aladinbama
- Current bike(s): 2000 Kawasaki Voyager XII
1997 Honda ST1100 - Has liked: 1 time
Any tips for getting this little bugger out?
I've got the forks off and in a vice, but am hesitant to putting that much pressure on a common allen wrench!
I need to replace my seals and this is all that is in the way :)
Thanks!
Thanks!
- Aladinbama
Re: Front Fork Allen bolt at end
I went and purchased some longer shaft hex sockets.
Off a recommendation of someone elsewhere I used an impact wrench and the said longer shaft hex socket (6mm). It stripped - YEAH!
Meanwhile I had the other fork bolt soaking in PB Blaster. I took a wrench and the above hex socket to it and it was sticky, but it came loose!
So, what do I do with the other fork? I'm attempting to dig the seal out, but I'm not sure that is really doable. I guess I'll try to drill the allen bolt head off (carefully - lol) and then get the rest of the bolt when it comes apart. Any suggestions would be appreciated.
Shooting it is definitely an option (lol).
- Aladinbama
I drilled out the stripped bolt!
All should be good (as soon as a busted knuckle heals a bit
Good job, now go buy an impact driver, best money you'll spend for your motorcycle
- Aladinbama
- Has liked: 890 times
- Been liked: 313 times
When I resealed my forks,I also found the bolts hard to loosen,so I used the smallest tip we have for our oxyacetylene torch and aimed the tip at the bolt head 5 seconds for each one.They came out without much resistance
I am gong to guess HBM Don is referring to an impact driver you hit with a hammer to try to shock the fitting loose.
I often use mine in a case like you had,they not only try to turn the fitting when you hit them,they also shock the fitting with each hammer blow,and are quite effective.
- Van Voyager
- Has liked: 51 times
- Been liked: 44 times
I've drilled many of them out over the years. Usually find the left over stub unscrews using just fingers.Aladinbama wrote: ↑Tue Oct 29, 2019 2:11 am I drilled out the stripped bolt!
All should be good (as soon as a busted knuckle heals a bit )!
- Aladinbama
All put back together and rolling. The progressives are tons better than stock. My stock front end had issues, but it's pretty tight now!
