I decided to start a new thread, maybe it's cleaner that way.
I had an '86 come at me from an estate. I might have let it go by but it only has 6078 miles on the clock and the cosmetics are very good to excellent (under a layer of sat-in-a-garage for a decade or more).
I worked my way past the previous owner's security kill switch installation, mainly a rocker switch adjacent to the fuel filler cap. It cranks fine, now.
But now I seem to be not getting spark: with a new plug in two different caps, nothing doing at the business end.
I've gone through just about every new owner info post I could find but am not seeing a no-spark thing.
The connectors I've been able to inspect all seem fine. After all, the bike hardly even saw the light of day.
I have been staring at the wiring diagram at great length and nothing obvious is jumping out.
Tinkering time on this bike is a bit limited, as it's kept in a storage container five miles from home from the time being. I'm no novice at chasing electrical issues- I had more than a few Brit bikes in the past. I rode my BSA twin for some 40K, but that thing didn't have Lucasitis.
I did have a Velocette Thruxton for a good while. Lighting was optional, but it wasn't my option to choose.
So, any hints?
Thanks
Bill
Resurrection of an '86, it begins
- Current bike(s): 2009 FJR1300
2000 VFR800
1999 CBR1100XX
1986 ZG1200
Permitted to maintain the Missus' Ninja 1000LT - Location: SW Chicagoland
- Been liked: 4 times
2000 VFR800
1999 CBR1100XX
1986 ZG1200
Re: Resurrection of an '86, it begins
Further occasional diddling around. Tried the original ECU, still no dice. Don't see a connector adrift yet. Wonder now if having disconnected the fuel pump so it doesn't run while I'm testing other stuff- the fuel tank is empty and it's pulling air- might somehow be breaking an ignition circuit.
Seems pretty far fetched.
Only getting hands-on sporadically doesn't help with either making progress or with mental continuity.
- Has liked: 107 times
- Been liked: 277 times
Bill;
it sounds as though the Black/Red wire from the Starter Button may not be a closed circuit when the button is pressed. This could be due to either a malfunction in the button contacts themselves or if not the contacts in the button housing then possibly the plastic connector this Bk/R wire runs through may be suffering from corrosion on the terminals.
A simple check is to check voltage on the Black wire/s connected to the Starter Circuit Relay while depressing the Starter Button with the Ignition switch turned on and the Engine Stop Switch set to RUN. You should get battery voltage which would then, once reconnected to the relay, energize the Starter Circuit Relay and turn the motor over.
The Black wire, in the main harness, by the way is what the Bk/R becomes after the first connector down from the handlebars.
You can also bypass the starter button with a jumper wire used on the main harness side of the above mentioned connector by jumping the Red and the Black wire and the starter should operate. Of course the transmission would have to be in Neutral or the lockout would over ride any starting circuit closure.
At least that's the way I see it but I may be wrong. Hope that helps in some small way,
- Has liked: 481 times
- Been liked: 436 times
How about the usual suspect for odd electrical problems (and I'm surprised nobody's mentioned it already) the 10-pin connector?
- cushman eagle (Wed Dec 22, 2021 2:39 am)
South Jersey Retreads
Patriot Guard Riders
Warriors Watch Riders
2000 VFR800
1999 CBR1100XX
1986 ZG1200
Dave- Maybe I wasn't as clear as I could be. The engine is cranking fine. It's that I'm not seeing a spark at a new plug set in a boot and grounded.
Denny- I will have a look there. But I have to say, with the bike only having 6000 miles, and having been stored in a garage all along, I have not yet seen any notable corrosion on any of the connectors I've had occasion to open up.
I might have a bit of time today and not-too-severe weather, so I can get there with the meter and see if I can track it down. I've already printed out the wiring diagram in oversize to pore over, and I do have the factory service manual at hand.
Then I can go back to worrying about the carbs.
- 1
- Current bike(s): 2002 voyager 7
- Been liked: 6 times
Hello,I know this,is,a,old,post, bit having tje same problem, no spark, did you ever found out?
