Clutch Cable lubrication Video??
Chris Cochran
2006 Vulcan 750
1986 Voyager XII
Has liked: 61 times
Been liked: 58 times
Post by Chris Cochran »
Is there a video where I can watch our clutch cable getting lubed?
And, for that matter, another one for lubing the speedometer cable?
Chris Cochran
2006 Vulcan 750
1986 Voyager XII
Has liked: 61 times
Re: Clutch Cable lubrication Video??
Disregard the clutch cable request. I meant the choke cable.
Has liked: 239 times
Been liked: 623 times
Lots of stuff about these topics on the web, if not right here. I recommend lubing all that cables as a matter of routine maintenance.
Chris Cochran
2006 Vulcan 750
1986 Voyager XII
Has liked: 61 times
I'm not so interested in the actual lubing of the cables since, as you say there are plenty of videos as to how to do that. I'm more interested in the actual disassembly of the left/right handlebar control boxes to get at the cables in the first place.
The brakes and clutch are hydraulic.
Chris Cochran
2006 Vulcan 750
1986 Voyager XII
Has liked: 61 times
I know, Nails. I corrected myself and changed it to "choke", which I actually meant.
Apologies. I'm just from the gym and fried right now.
Sections 2-8 and 16-8 of the manual have limited info. I've slept a few times since I got into this, but I don't remember it being especially difficult. IIRC, by the time you remove those two screws on the bottom and split the left switchset, the choke mechanism pretty-much falls apart. Note that one of those two screws has a bracket that supports the choke outer cable.
cushman eagle (Fri May 20, 2022 12:48 am) • Chris Cochran (Fri May 20, 2022 3:55 am)
