Abs repair
grumpy72
99 shadow 1100
93 voyager 1200
Been liked: 15 times
Abs repair
Post by grumpy72 »
I havent looked in years. But a company called plastex used to make repair kits. They had a wonderful video you can watch for free. All those broken mounting tabs, or screwholes they show how to do it. Plastic welder? No.this is much better.
These users liked grumpy72's post:
cushman eagle (Sun Jul 17, 2022 7:46 pm)
Has liked: 902 times
Re: Abs repair
Thank you grumpy 72
I do not have any broken parts right now but that can always occure :thmup:
Been liked: 249 times
Re: Abs repair
I used ABS Glue from Ace Hardware on two Vetter fairings, as well as my Voyager's Tupperware. It is ABS Plastic suspended in Acetone: once the Acetone evaporates, there is only plastic left behind. My repairs have lasted 10+ years, so far. Cheers!
grumpy72
99 shadow 1100
93 voyager 1200
Re: Abs repair
Post by grumpy72 »
Abs glue is good. But the plastex video shows how to create mounting points.
grumpy72
99 shadow 1100
93 voyager 1200
Re: Abs repair
Post by grumpy72 »
How do i reach carl leo?
Has liked: 242 times
Been liked: 631 times
Re: Abs repair
I search here on his name.
Chris Cochran
2006 Vulcan 750
1986 Voyager XII
Has liked: 61 times
Been liked: 58 times
Re: Abs repair
Post by Chris Cochran »
This bike has ABS??
Re: Abs repair
Most of the XII bodywork is Acrylonitrile Butadiene Styrene, I think the only common plastic that dissolves in acetone. ABS cement is just some ABS dissolved in acetone. It chemically (and literally) welds ABS, as opposed to adhesive glues that just stick to it.
Chris Cochran
2006 Vulcan 750
1986 Voyager XII
Has liked: 61 times
Re: Abs repair
Ohhhh, I saw "ABS" and I thought brakes. Ok, I got it now.
Re: Abs repair
grumpy72 wrote: Sun Jul 17, 2022 3:38 pm All those broken mounting tabs, or screwholes they show how to do it.
My lower Tupperware pieces had broken out screw holes and anchor points on them. I repaired them using ABS Glue by applying masking tape to cover the screw wells (holes), then I painted in ABS Glue. After it dried, I peeled off the masking tape, I drilled a new hole for the screws... Note that the masking tape is not smooth, and the ABS Glue will assume the texture of the tape (rough). It ain't perfect, but if it bothers you, feel free to sand with 200/400/600/1,000/1.200 grit sand paper to achieve a smoother finish. ;-)
What I ignored was that there was torsion on the Tupperware which led to the screw well breaking, initially. I was unable to relieve that stress, so my repairs broke, exactly like the original factory molded plastic. As stated ABS Glue bonds/welds with the plastic, it does not adhere to it, it melds with it.
Long story short: you might be able to fix the broken bits, but if you do not relieve the stress which caused the OEM parts to break, history will repeat itself.
My solution was to use black plastic Zip Ties, looped through the holes, cinching the parts together, somewhat loosely. The Tupperware holds together, looks fine, at arm's length, and no more fractures of the plastic. This is a limited solution, obviously, but if you can make it work, it is simple, and it can be highly effective. I cinched my Tupperware together, 11 years ago. Still holding together, around 40,000 miles later.
As to the burning question, "How do you disassemble it for maintenance?", and, "How do you re-assemble it after maintenance?"
"Cut the Zip Tie with a pair of wire cutters," and, "Use a new Zip Tie to re-assemble it."
I can feel everyone grimacing and cringing... Relax! Crack open a beer. Sit in your chair out on your porch/deck/lawn. Take a deep breath, and let it out, s -l-o-w-l-y... I am not the owner of a Garage Queen bike/car/whatever. I am a practical man who enjoys what he has, even if it is... Blemished. (Gasp!) If that bothers you, I recommend that you avoid reading all of my posts...
:gig: :devl
Cheers!!
Has liked: 506 times
Re: Abs repair
"My Kawasaki is a tie-wrap queen,
She's held together no bolts to be seen
I don't know how she don't fall apart
Oops lost another screw over here"
My apologies to the Stones.
Nails (Wed Jul 20, 2022 5:42 pm)
