1999 Voyager XII Air Cleaner Question
- Current bike(s): 99 Kawasaki VoyagerXII
I was wondering a good place to purchase a new air cleaner element. My bike sat quite awhile and a mouse got at the air filter. Also the foam around the outside is deteriorating and sucking into the carbs.
- Has liked: 505 times
Re: 1999 Voyager XII Air Cleaner Question
Look in the Tech section under "dollar for dollar".
Thank you
- These users liked BOBEYE22's post:
- GrandpaDenny (Tue Apr 11, 2023 4:52 pm)
You'll see a post about using a Camaro filter, I think, using the frame of the stock Voyager XII filter. This is what I did, with a K&N filter. The K&N filter listed for the Voyager XII no longer exists, so I used one for whatever it was they say, I forget. Used Permatex to seal the gaps, and used a couple of layers of the rubber that came with the filter to build up the top to correct for the missing air filter hold-downs.
- Has liked: 902 times
- Been liked: 316 times
Hello,BOBEYE,and welcome to the AVA family
Partzilla shows that air filter element, in stock,as part number 11013-1137,for $38.58
- Current bike(s): 1989 Voyager XII
- Been liked: 16 times
I ordered 1 through Partshark just last night. Got an email today saying it was on a national backorder and has been discontinued by Kawasaki.cushman eagle wrote: ↑Wed Apr 12, 2023 7:36 pm Hello,BOBEYE,and welcome to the AVA family![]()
Partzilla shows that air filter element, in stock,as part number 11013-1137,for $38.58![]()
That is disappointing
I have no other suggestions.
It is disappointing.
I should have an oil bath off an old Case DC if you think that could be crammed in there....
https://www.amazon.com/gp/product/B000C ... UTF8&psc=1 is the K&N filter I bought off Amazon. YIKES the price has gone up by thirty bucks since I bought it a bit over a year ago. Holy smokes I installed in on 3/2/22, and have put 25000 miles on her since then, without going on a long trip, just commuting and occasional club rides. Wow.
The K&N filter is for an '85-'92 Camaro, and fits inside the plastic portion of the stock air filter element. Just pull all the paper out. I didn't have to do any trimming, and I filled in the gaps around the element with black RTV. The filter hold-downs have been missing the whole time I've had Gertrude, so I used the rubber that came with the filter to fashion spacers to hold the element down.
If the foam rubber around your existing element is toast, you can use stick-on weatherstripping foam tape from Home Depot in the appropriate size.
....and a brand new air filter showed up today with the two headlights that were ordered at the same time.sheiserman wrote: ↑Thu Jul 20, 2023 5:50 pmI ordered 1 through Partshark just last night. Got an email today saying it was on a national backorder and has been discontinued by Kawasaki.cushman eagle wrote: ↑Wed Apr 12, 2023 7:36 pm Hello,BOBEYE,and welcome to the AVA family![]()
