Fuel line size
hwyman
4
Current bike(s): 1979 Honda CB750F
1997 Kawasaki VN750
I am currently looking to purchase a Kawasaki Voyager
Fuel line size
Post by hwyman »
Can anyone tell me the ID of the fuel line from the tank to the pump? I need to replace mine and want to pick it up on my way home from work this afternoon
Thanks
Has liked: 505 times
Re: Fuel line size
hwyman wrote: Thu Nov 30, 2023 8:16 am Can anyone tell me the ID of the fuel line from the tank to the pump? I need to replace mine and want to pick it up on my way home from work this afternoon
Thanks
92059-1724
hwyman
4
1997 Kawasaki VN750
Re: Fuel line size
Post by hwyman »
Thanks
I didn’t realize it was a molded line. I was going to just use a piece of universal fuel line. I called local dealer and was told it is no longer available but I did it on partzilla
Has liked: 119 times
Re: Fuel line size
If you are using a worm gear clamp, on the tank end of the fuel line, be sure that the clearance between the swing arm and this clamp is sufficient to NOT bend the tank outlet/spigot under driving conditions.
Ideally one still can use the OEM spring clamp provided it is still there and in good condition.
Just a heads up about that.
hwyman
4
1997 Kawasaki VN750
Re: Fuel line size
Post by hwyman »
Well I just got a refund from partzilla for the cost of the fuel line.
It looks like I am going to need to use a piece of universal fuel line. Can someone tell me what size fuel line to get?
Thanks again
buzzcut
4
Current bike(s): 2001 zg1200, 1986 zg1000, 1983 gs1100, 1981 cm400a
Been liked: 39 times
Re: Fuel line size
Post by buzzcut »
pretty sure its a 5/16 id. def larger than 1/4. best not to quote me lol
