Liking the bike so far, but I noticed an odd noise and I don't know if it's normal operation or not. When I turn the key to the RUN position, the throttle actuator motor makes a continuous whining sound. Even if the kill switch is in the OFF position. I expected it to do a system check and then hush up until it's actually running, but this thing just keeps on with the annoying whine. Is that par for the course or is mine on it's way out or something?
I pulled the right side cover and the throttle plates operate (open and close) while turning the the back and forth, and all seems fine... other than the noise. I can't hear the noise if I start the bike as the engine and exhaust drown it out.
Thanks for any insight!
