Gear indicator
DougColson
Current bike(s): 2003 voyager 1200
Gear indicator
Post by DougColson »
Does anyone know if a digital gear indicator can be installed on a 2003 Voyager 1200?
Thanks
Has liked: 506 times
Re: Gear indicator
DougColson wrote: Fri Oct 04, 2024 12:10 pm Does anyone know if a digital gear indicator can be installed on a 2003 Voyager 1200?
Thanks
I was looking for one myself, and what I found were ones that worked with vehicles with electronic speedometers, not mechanical. For some reason I seem to recall (and my memory is far from perfect) my '82 KZ550 had a gear indicator but no Positive Neutral Finder. Perhaps they are mutually exclusive?
Van Voyager
Has liked: 52 times
Been liked: 44 times
Re: Gear indicator
Post by Van Voyager »
There are generic ones that work with up/down sensors and a magnet glued to the shifter arm. Better ones include a wire to tap into neutral light to indicator neutral (and to reset the indication position).
Something like this one (I wouln't choose this one as there are probably better ones at lower cost)
https://www.amazon.ca/Digital-Indicator ... =1-25&th=1
Has liked: 242 times
Been liked: 631 times
Re: Gear indicator
I only need to know whether I'm in 5th ... and I can tell because it refuses to go into 6th. :gig:
(No diss intended for folks who want to know more than that.)
Van Voyager (Mon Oct 07, 2024 5:05 pm)
